HELP! Removing rusted brake drums.
Old Jun 12, 2008 | 05:46 PM
Dre2932's Avatar
Car Info: Women Crazy
Question HELP! Removing rusted brake drums.
I'm going to switch out the brake drums on my 93 Impreza with new ones, but I ran into a problem. The drums are really rusted on and its near impossible to get these suckers off. Have anyone had this problem before and how do I deal with it?
Old Jun 12, 2008 | 06:35 PM
nkghost's Avatar
Car Info: 2002 MBP WRX
I would think that first you want to get them cleaned off in that area as much as possible. Any Rust remover that's strong (heck WD-40 might work) and a metal brush to scrape it off might let you diagnose the situation better. Can you snap a picture of where the build up of rust is based on where you are having trouble?
Old Jun 12, 2008 | 10:12 PM
Find 2 high-grade 12mm bolts (head size; the ones holding the rear seat cushion on are the correct thread but not strong enough) and use them to pop off the drum. There should be two tapped holes inside of the lug circle on each drum. It is the same method for removing rusted-on discs. Tapping/pounding with a hammer or mallet will help, but won't do the job by itself usually.
Old Jun 13, 2008 | 11:12 AM
LunarHonour's Avatar
Car Info: STI 2006 White Stage 666
I used that method on an Eclipse, works good... Also heating with a torch can help loosen it up...
Old Jun 13, 2008 | 11:20 AM
darkonion's Avatar
Chicks dig me. April Fool's!
Make sure the EBrake isn't engaged. PB Blaster it, and use a rubber mallet.
Old Jun 13, 2008 | 09:43 PM
Dre2932's Avatar
Thanks a bunch everyone. I'm going to use all these methods. I'll let everyone know how it goes.
EndlessWaltz RS
Dec 5, 2004 10:13 AM
meilers
Feb 24, 2004 08:36 PM
meilers
Feb 13, 2004 03:51 PM
meilers
Jan 27, 2004 10:29 AM
stentorian
Sep 23, 2003 09:17 AM
