Engine Oil Change DIY
Old Feb 16, 2012 | 11:35 PM
jagan323's Avatar
Car Info: 2006 Subaru STI
Machine Zealots - Subaru STI Engine Oil Change with German Castrol Syntec - YouTube
Hope this helps anyone who needs it =)
Afterthoughts and other things can be found on the blog:
Machine Zealots: Subaru STI Engine Oil Change
Old Feb 21, 2012 | 10:07 AM
04GG's Avatar
If in doubt, FLAT OUT
Dropping the under tray helps, but isn't necessary. You can get the filter out without removing it.
Old Feb 23, 2012 | 06:06 PM
PikkaGTR's Avatar
ditto,
I never removed it when I did my oil change
Access was not great, but it's there
Old Mar 4, 2012 | 09:25 AM
jagan323's Avatar
Wow, that's pretty amazing. How did you go about draining the oil? I personally don't mind removing the skidplate, doesn't take long anyways, but I'll definitely check out the clearance the next time I get under there.
Still suprising to me
Old Mar 7, 2012 | 03:34 PM
04GG's Avatar
There is a weep hole in the tray that the oil from the funnels into, which actually makes it quite simple. The oil drain plug isn't covered (at least on 04 it isn't). You have to angle your arm in and have a filter wrench that fits, but it isn't that hard.
Fa9-Wrx
Apr 29, 2007 08:17 PM
evsoul
18
Oct 26, 2006 12:44 AM
tekgnosis
14
Sep 7, 2006 05:21 AM
neptune
May 12, 2004 10:38 AM
Peaty
Forester General
Feb 13, 2004 04:19 AM
