Replacement Engine Belts
Old Jan 14, 2004 | 11:29 PM
iNfEk's Avatar
I'm looking to replace my timing belt soon and know that PE makes (from what I've heard) a good replacement timing belt... My question does another company make replacement belts for the other belts for my car?
Jon
Old Jan 14, 2004 | 11:47 PM
oldmansan's Avatar
I thought
Subaru made a beefier one than stock.
San
Old Jan 14, 2004 | 11:50 PM
iNfEk's Avatar
really? which belts?
Jon
Old Jan 15, 2004 | 12:09 AM
oldmansan's Avatar
There is an
STI belt, but from what I read, it's a copy of the PE belt. Unless someone has something bad to say about the PE belt (haven't seen anything negative) I'd go with it.
San
Old Jan 15, 2004 | 02:11 AM
IS2Scooby's Avatar
Pr0n King
Car Info: Turncoat Turbo
How many miles on your engine? Why are you looking to replace you timing belt already!?!
__________________
Old Jan 15, 2004 | 10:32 AM
iNfEk's Avatar
I got 40K+...
I'm really not looking to replace only the timing belt... I'm really looking to replace the other belts... I figure since I'll be messing with all the belts I should just do them all at once...
Jon
Old Jan 15, 2004 | 07:55 PM
iNfEk's Avatar
bump
Old Jan 15, 2004 | 08:35 PM
markpaco's Avatar
Car Info: AWD/FWD/RWD
I'm not too familiar with Subarus specifically but timing belts are much more involved compared to accessory belts. This is because they are covered and have to be installed with everything (crank and 4 cams in this case) timed correctly. When I replace timing belts I usually replace the drive belts instead of the other way around.
Old Jan 15, 2004 | 08:39 PM
iNfEk's Avatar
I know that if I'm going to be removing belts to get the timing belt I might as well replace them as well...
Jon
- I'm looking for aftermarket belts BESIDES the timing belt
Old Jan 15, 2004 | 08:51 PM
markpaco's Avatar
Oh ok. The way your message read implied to me that you were really looking to replace the other belts. Well regardless, what is the recommended time to replace your timing belt? I believe that my Subaru recommends it at like 100k which seems a bit long. My Integras were recommended at 60k and 90k. 40k is the shortest I've ever heard of.
Old Jan 15, 2004 | 10:13 PM
iNfEk's Avatar
I think the recommended is 60K but since I drive it hard pretty often it might be time... Also I have a screatching noise when I reverse and turn my wheel (not all the way to lock) and another i-clubber said that it could be a bad belt...
Do you know of another manufacture that sells performance belts (stock size) for the 02 EJ20?
Jon
02ScoobaruWRX
Mar 7, 2008 10:51 AM
mysubaruimp
May 12, 2003 04:29 AM
Impreza_WRX_STi
Jan 27, 2003 09:43 PM
stealth-wrx
Nov 24, 2002 09:05 PM
