Need help with E-brake!!!!
Old Oct 12, 2004 | 03:33 AM
shaggadelic's Avatar
Unhappy Need help with E-brake!!!!
today I noticed that my e-brake light will stay on while i'm driving my car even tho my e-brake is all the way down and the only time it will disapear is when i push the gas. i don't knw what its from i don't really use my ebarke unless i'm on a hill and parking. Is there a nut that i can play with that will make the senser go away? or is there something messed up??? i did a search but it didn't really help much they talk more about wrx then my car which is a 94 impreza L fwd.
heres were i searched but it did no help
https://www.i-club.com/forums/search...earchid=134610
sorry if this is a stupid question but i just wanted to ask b4 i took the center consle out to play with it.
Old Oct 12, 2004 | 03:57 AM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
this might be a really stupid question-
did you check the brake fluid level?
(reason why i say that is that i had a 84 corolla once-same symptoms- filled with brake fluid. light disappeared.)
Old Oct 12, 2004 | 04:01 AM
its between the max and low lines so theres enough fluid
Old Oct 12, 2004 | 04:38 AM
04sleeper's Avatar
i think greg might be on the right track. i had this prob with a car of mine. it turned out to be the master brake cylinder was bad. it might also be that it is stuck(ie: rusty so the spring won't release it). take off the boot and see if the switch is dissengageing. check the cable for play or lack there of and try adjusting it a little. i would have someone look at it. you might have the same prob i did. hope this helps, L8R
Old Oct 12, 2004 | 06:16 AM
.:: 808 STi ::.'s Avatar
Car Info: "the loud one"
damn shaggy...too much drifting....broke ur e-brake....hahahahaha....just playin'....
__________________________________________________ _____________
Old Oct 12, 2004 | 11:28 AM
WRXed's Avatar
Car Info: cars
might be a loose wire or short from the ebrake to the dash indicator.
Old Oct 12, 2004 | 08:01 PM
Peaty's Avatar
Put more fluid in up to the MAX line see if that helps. I've seen that do the trick before.
http://www.scoobymods.com/forums/showthread.php?t=1803
Old Oct 12, 2004 | 08:25 PM
its almost full there is alot of fluid left well someone told my that my nut in the back is probly lose so just to thighten it. thanks for all the help i just gotta wait till i get my car back b4 i knw if its the nuts fault
Old Oct 12, 2004 | 08:46 PM
nic3krnnamja83's Avatar
actualy just had this problem today just fill it up a little not enough pressure in the brake lines it will go away
unstble
Mar 21, 2008 09:09 AM
mechanizedmedic
Aug 21, 2005 11:49 PM
gdogg
Apr 21, 2004 07:31 PM
six1five
Dec 15, 2003 03:59 PM
