Jacking up engine on passenger side
Old Apr 29, 2013 | 01:20 PM
abakja1's Avatar
Car Info: 08 Nissan Titan, 12 MazdaSpeed 3, 15 Honda CRV
Originally Posted by 04sleeper
i don't recall needing to jack up the motor either when i did mine however i do remember it being a PITA.
Thats what ive read about uppipe installs. Some subies come out fine, others cant without jacking up the motor. Coming out the top is a no go as turbo in the way and i dont want to mess with the rubber intake.
I did my lgt and a friends legacy gt too with some resistance, but they came out. Yesterday, trying to take out the uppipe was a no go. I got as far as clearing the power steering line, but the top flange just had no space to come out the bottom. The egt clears, but the top flange hits the block no matter how i wiggle it out.
Old Apr 29, 2013 | 01:39 PM
04sleeper's Avatar
where are you located? if you want some help i'd be down to take a look for you
Old Apr 29, 2013 | 02:24 PM
GOKU 4's Avatar
Car Info: 2011 KTM 530 EXC Supermoto
Send me your address too. I wouldn't mind checking it out. If worse comes to worse, taking the turbo off isn't that bad. I have some silicone and a make shift rubber puller to slide the inlet back on the turbo. Plus, trying to earn some brownie points so I can possibly score your stock mid-pipe.
Old Apr 30, 2013 | 12:52 AM
abakja1's Avatar
Thanks everyone for the advice and help.
Took off passenger engine mount bolt and jacked up transmission housing with block of wood. Uppipe came out after rotating it. Top flange had to clear the block. Just got to put the downpipe back on tomorrow as i ran out of daylight and time to feed the babies and put them to sleep. Hopefully the 2.2kohm resister mod works for up pipe and PDE downpipe o2 bung wont throw any codes for the sensors as i dont have an ap.
Goku4 pm me this weekend and we can work something out unless you're close to salt lake area to pickup the midpipe.
rally_wrx
Hawaii Classifieds
Feb 2, 2006 03:05 PM
bo123
Jan 28, 2005 11:18 PM
Scooby42
Wanted
Oct 1, 2004 01:24 PM
DsmWRX02
Mar 15, 2004 06:26 PM
superbludouble
Wanted
May 2, 2003 11:12 AM
