Cobb problems! I hope someone can help.
Old Oct 12, 2004 | 12:38 AM
keirnna's Avatar
Car Info: 1996 STI V3 Type RA
Okay, I got my access port last week, and let me say up until this is was great. I just put my downpipe on, so I went to set my AccessPort to stage 2, and everything went fine. I then checked my sttings to see what my current map was, but it didn't change from stage 1 91 to stage 2 92. I am really worried now. I changed my base map no problem, but everytime I try to change my realtime map, it says okay, and then it didn't actually change. It was the exact same problem. Please help. I spent over 5 hours trying to get this to work today.
Old Oct 12, 2004 | 12:52 AM
iNfEk's Avatar
Post
ok... I'll help you out...
When you check the settings in "Current Map" it will ONLY display the map that is FLASHED to your ECU (aka BASE MAP). This has been discussed numerous times at http://www.wrxforum.com/cgi-bin/ulti...ubb=forum;f=11 this doesn't mean that your map didn't change and doesn't mean your AccessPort isn't working right since it is.
One way to test to see if your map is changing is to choose "Change Map" (aka REALTIME MAP) and choose valet mode. It will say successfully loaded then go for a drive... once you hit about 4K RPM your car will feel like it hit a brick wall... this is what happens when you have the valet mode map loaded the ECU is limited to ONLY 4K RPM.
All I can say is do a search LOL j/k
Dude you should really read up on what you buy before you buy it..
Jon
Old Oct 12, 2004 | 12:54 AM
saltysti's Avatar
Car Info: 04 wrx sti
try to download the most recent revisions made on cobb's web page. im more than sure there is like several base maps to choose from.
http://www.cobbtunning.com/sti/accessport
there are the newest revisons on stage 2 maps
hope this helps..
Old Oct 12, 2004 | 01:24 AM
04sleeper's Avatar
Roofscoop!!
Old Oct 12, 2004 | 01:37 AM
STiNightFall's Avatar
From: 12.88@102.27mph w/ 1.5 60ft no tune, no problem!
Car Info: 02 wrx
get a utec
Old Oct 12, 2004 | 01:40 AM
CallMeCrazy's Avatar
Car Info: 2008 Legacy 3.0R 3L H-6 RIP :( Hello 09 FXT!
sorry roofscoop, i'd help but as you know, i'm having more problems w/ it than even you.....actually this is 808subaru, not crazy...
Old Oct 12, 2004 | 02:10 AM
outlaw23's Avatar
Nate, first of all, you should not be using a stage 2 map until you completely install your turbo back exhaust. Since you don't seem to like to read or follow instruction here is an easy way to learn: First of all, the "Show Current Map" will only show your base map. If you want to change from your base map you need to select "Switch Map" and then press OK, which will give you a list of your realtime maps. Choose a map you want to use and then press OK again. When you see the words "Done" at the bottom left your realtime map has been successfully loaded and will be the map in use. Like Jon said, try these steps with another realtime map, i did it using the anti-theft map to see if it was actually working and it was. Again, i want to tell you that our cars are very tempermental and the cobb access port is a unit that seems to work most efficently when you follow instructions to the tee. Another way to tell if your cobb is using the right map is to install a boost gauge, which you will have once you install your blitz turbo timer. I noticed right away that the stage two map boosts higher in 5th gear than the stage
Old Oct 12, 2004 | 02:12 AM
bpang1's Avatar
Car Info: '04 WRX Wagon
....as if I knew.
I WANT ONE TOO!
Old Oct 12, 2004 | 02:46 AM
keirnna's Avatar
Everyone, thanks so much for the prompt help, and I did search on google, i-club, and cobb's forums but I didn't find anything. I figured this out by trying valet mode right after I posted. I was so mad, that I didn't think clearly. Jon I read the entire instruction manual. I bought this on recommendations and I am very impressed with it. Well sorry to be such a post ***** since this is only about my 3rd post in a while. Well thanks for the help.
Old Oct 12, 2004 | 02:50 AM
keirnna's Avatar
It's actually 3200 RPM, I knew that since I read the manual!
Old Oct 12, 2004 | 03:09 AM
shaggadelic's Avatar
is this ur womens screen name??
Old Oct 12, 2004 | 04:43 AM
04sleeper's Avatar
psssss......
at least you have one, or an exhaust for that matter. BTW i swear i can still smell it when i drive around. no wonder you make sushi...nothing to burn.
Old Oct 12, 2004 | 06:15 AM
.:: 808 STi ::.'s Avatar
Car Info: "the loud one"
Originally Posted by bpang1
....as if I knew.
I WANT ONE TOO!
so do i......
__________________________________________________ _____________
Old Oct 14, 2004 | 10:58 AM
iNfEk's Avatar
really? I guess they've changed it for the STI then since mine isstill 4K oh well maybe I'll have to get the updated maps
Jon
Old Oct 14, 2004 | 11:42 AM
WRX151's Avatar
I had this same problem. What I did was flash it back to stock and reload your modified base map. It fixed the problem for me.
Lar
Mikkito
Jul 20, 2006 05:01 PM
grex767
May 27, 2006 10:37 AM
Scoobyvroom
Feb 5, 2004 01:17 PM
