tire pressure light...
Car Info: past 06 WRX, present 08 STI
i put on some wheels and now the tire pressure lights is on, is there a way to make it go away... i know the sensor is sensitive but i wanna keep the rims on... thanks for the help...
Dang Paul! 7:39 in the morning?
Perky, When you change wheels, you need to swap over the TPMS sensors from the stock wheels to the new ones or the light will come on (because the sensors are missing).
Tire Pressure Monitoring System
There is a control box in the trunk somewhere, and there are sensors in each wheel attached to the valve stem.
Honestly the light is just that, a light. If you know that your tires are properly inflated then you really don't have much to worry about other than having the light glowing at you.
suby_dude
Feb 12, 2008 01:28 PM
