General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
Perrin crank pulley help...
Old Aug 2, 2010 | 02:31 PM
SDTONORCALWRX's Avatar
Car Info: 09 WRX E85 tuned
So I was trying to install a Perrin light weight crank pulley on my 09 WRX and I ran into a problem. I have no idea of how to get the belt off the A/C and factory crank pulley. There are no tention bolts and I can't figure out a way to get it off. The 02-07's have tension bolts but I guess they changed that for the 2008's and beyond. Has anyone tried to put one of these on? I need your help! Thanks!
Old Aug 2, 2010 | 06:42 PM
bobbyjimmy's Avatar
Car Info: A Car
You cut it off.
As you know they use a tension/stretch belt and the instructions for the new belts say to cut off the old one, you get a "tool" with the new belts to help put the new one on.
You can retrofit the older style tensioner set-up to make it easier - you then need the older length belt too.
You didn't do any research before you bought it?
Old Aug 5, 2010 | 12:08 PM
I guess not enough... I watched the video that Perrin has on their website but I assumed that it was the same for the 08's and up. I didn't realize that Subaru took of the A/C tention bolts for the late models. *** U ME! LOL
I heard about cutting the belt but I wanted to see if anyone had a better solution. Thanks for your input.
demonbugeye
Hawaii Classifieds
May 4, 2009 03:26 AM
lburrrna
Apr 12, 2007 08:24 AM
Speed Element
Feb 18, 2007 10:29 AM
Speed Element
Engine and Drivetrain
Feb 8, 2007 12:27 PM
JamesIV
Jun 18, 2003 01:50 AM
