General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
New 2010 WRX - Rough Acceleration in Tall Gears
Old Aug 10, 2010 | 05:49 PM
vazqued2's Avatar
Car Info: 2010 WRX
Hey guys,
Just picked up my 2010 WRX about a month ago, and have put about 1200 miles on it so far. I have noticed a troubling behavior on the highway, particularly in 4th and 5th gears. Right around 3,000 rpm, if I depress the throttle to part-throttle or WOT, the car seems to accelerate pretty roughly up to around 4k. This is my first turbo car, but it still doesn't seem normal. I followed the break-in procedure, and use premium fuel. It's not lag either; it's more like a hesitation than actual turbo lag.
It seems like most people here suggest that the factory tuning is the culprit, but I find it hard to believe that it could be that bad. I hesitate to get a tune just to see if that's the cure. Anyone else notice this phenomenon, and is it normal? Does it go away after a few thousand miles?
Thanks for any responses.
Old Aug 10, 2010 | 06:01 PM
Alliedforces86's Avatar
Car Info: FR-S + WRB Bugeye.
take it to the dealer and have them reflash the ECU with the stock Subaru tune if you think it's the tune. I'd make em do it for free. Check to see if you happen to have any vacume lines disconnected. But it could just be lag. Or might need to be broke in a little bit more. idk, hope that helps a little...
Old Aug 12, 2010 | 01:10 AM
hwob90's Avatar
Car Info: 2009 WRB WRX Sedan
mine has sorta of a lag on 4th and 5th. not too bad though. especially at low rpms its does like a jutter then catches rpms.
Old Aug 16, 2010 | 12:57 AM
PikkaGTR's Avatar
sounds like stock tune on the 07 Stis
look into asking the dealership for a new flash/tune
Old Aug 26, 2010 | 04:51 PM
kwiksilverwrx's Avatar
Car Info: 2015 WRX Limited (sold 2009 WRX beast)
ive kinda noticed it on my 09 hatch. gettin on the freeway it would delay then pick back up. i havent though much about it but maybe ill take it in. My stupid anti-roll light keeps comin on randomly too. any one else have THAT issue?
brucelee
Nov 7, 2008 03:30 PM
KevinWannaBfast
Jun 28, 2006 07:30 PM
TallPinesRally
Rally
Jun 12, 2006 05:35 AM
