Turbo migration plan
Old Jul 30, 2003 | 06:48 PM
AWD OWNZ U's Avatar
Car Info: 2000 2.5RS
Add a new rear swaybar. I prefer 18mm, most prefer 20mm or an adj. unit. Throw on some heavy duty endlinks too. Short throw shifter w/ bushing if you have a 5spd. Then I'd go with WRX rotors up front, new pads, SS lines, and better brake fluid.
When are you going turbo? Generally speaking a turbo car and an N/A need different piping size.
JC
Old Aug 4, 2003 | 10:36 PM
You can really only use your headers for an RS-T. Exhaust past that is going to have to be replaced, as well as any intake you may be running. The good news is, quality exhausts for an EJ25 will be worth more than half what you pay for them new, so if it is going to be a while before you can afford the turbo, it's worth it to have the mods now.
Old Aug 4, 2003 | 11:08 PM
AWD OWNZ U's Avatar
You don't HAVE to replace the exhaust. It just won't be an optimal set-up. Intake does have to be replaced though.
JC
Old Aug 4, 2003 | 11:30 PM
If you're running more than 3-4 psi, a 2.25" setup would really be restrictive. It would run, but it wouldn't be fast.
Subdued
May 14, 2003 08:19 PM
twistedsymphony
Feb 20, 2003 09:10 AM
krillz
Feb 10, 2003 01:29 PM
nosuchsol
Jan 18, 2003 09:00 AM
