Someone bring me up to speed on borlas
Old Nov 30, 2002 | 12:30 AM
ImprezaRSX's Avatar
Big Baller
Car Info: 93 BG5, 00&01 GM6, 06LGT, 07STi
Originally posted by 25RS 2NV
OK i had them and this is my take on em. First off there bnot worth the money. Unless you want just sound. they do sound awsome. Performance wise you lose power wiuthout a doubt. i did get a check engine every 2500-3000 miles. just my 2 cents.
Erik
I disagree. In fact, I couldn't disagree more. I noticed a big difference in my car. Fourth and fifth gear pull much harder now. ALL gears do, but 4th and 5th were the most noticeable. Not to mention the car sounds great.
Some people get CEL's. I did until I wrapped the headers. The CEL went away and that rattling sound that people gripe about also went away. So the car sounded smooth, mean and performed better. Now that the Borlas are on sale for 275 bucks, I would say they are worth every penny. People who have them and wrapped them will probably tell you the same.
If you go turbo, they will hurt your spool a little bit because you lose some exhaust gas velocity. However, some cams will remedy that. Also, any turbo kit for a stock RS will bolt right up. Brullen and MRT headers would require a TON of fabricating to make most turbo kits work.
Parallel fuel rail modification is a VERY good idea. If you go turbo (and run any respectable amount of boost) the fuel rail mod is a necessity. This also means you can put the EGT in the uppipe and not in no.3 primary, so you don't run as high of a risk of cracking your headers.
edited for content because they *'d the word b***h as in gripe and complain.
Old Nov 30, 2002 | 12:35 AM
ImprezaRSX's Avatar
Big Baller
one more thing. ...
on adding a turbo:
fabricating a support from the turbo to the block would be pretty easy and would prevent any cracking or sagging for sure. I'll be doing it when I get mine.
Old Nov 30, 2002 | 12:57 AM
Kostamojen's Avatar
NASIOC Slut
Some people get CEL's. I did until I wrapped the headers. The CEL went away and that rattling sound that people ***** about also went away. So the car sounded smooth, mean and performed better. Now that the Borlas are on sale for 275 bucks, I would say they are worth every penny. People who have them and wrapped them will probably tell you the same.
I think that a comparison to other headers would show the borla's do not give as good of improvement as the rest of the field... They are much easier to work with and buy, as well as are stainless steel, which makes them apealing.
For the money, I would get the MRT's and the better performance.
Old Nov 30, 2002 | 06:49 PM
ImprezaRSX's Avatar
Big Baller
You are correct. The Brullen's and the MRT's give bigger power gains. However, adding a turbo kit to those headers would be a huge hassle. Also, the extra piping for that kind of project would hurt your turbo lag even more than the borlas.
Old Nov 30, 2002 | 11:10 PM
Kostamojen's Avatar
NASIOC Slut
Im confused again... Why are we discussing Turbos in a Normally Asperated forum???
