running lean?
Old Dec 23, 2003 | 10:20 AM
Frink's Avatar
Car Info: 2005 Legacy GT MT
running lean?
At what point in NA tuning would you consider it time for Reprogamming the ECU to avoid running lean? Lets assume the intake you are using is a Cobb intake. Lets also assume that the car uses MAP as opposed to MAF.
Old Dec 26, 2003 | 02:24 PM
Frink's Avatar
I was reading this article that was saying that when you put on your intake you should disconnect your battery and then reconnect it once the new intake is on. Apparently this will retrain your ECU for the proper fuel/air ratios.
Old Dec 26, 2003 | 09:00 PM
highspeed11's Avatar
Car Info: '05 LGT
You should reset the ECU when doing most mods to your stock car. All it is is pulling the negative battery cable pumping the brakes and holding for 15 secs. Then letting it sit for 30 mins.
It just resets the ECU back to factory settings then relearns on it's own with your driving style.
Old Dec 28, 2003 | 01:11 PM
Car Info: '05 LGT
The brake thing was the way it was told to me a few years ago. It's supposed to drain any remaining juice out of the system. Not sure how though, other than the brake light swiitch. I also turn my lights on but that's just me.
You cannot damage the vacuum booster by pushing the brakes with the engine off as it simply won't operate without vacuum. Also considering it's a part of the diagnosis of the brake system it should be okay.
Thanks for the better explanation of the relearn procedure.
Old Dec 29, 2003 | 01:53 PM
Car Info: '05 LGT
Re: ECU
Originally posted by Whitey
I work at a dealership selling chevys. My impreza has the Clarion cd player and the optional alarm system, how are these components going to react after I disconect the battery. The reason I ask this is chevys have a theft deturant system that requires a four digit number to be entered into the radio when the battery is disconected. Also, does this alarm system do the same thing?
I'm assuming your talking about a factory alarm and factory cd player. It will reset your clock and radio presets and of course your alarm won't work while the battery is unplugged. I've never heard of needing a code to be entered on Subarus of any year.
nu02wrx
Aug 6, 2003 01:16 AM
adria
Jun 1, 2003 09:25 AM
wonton2049
May 4, 2003 06:29 AM
Bean
Jan 22, 2003 01:44 PM
SmuttyStyles
Jan 1, 2003 06:43 PM
