is the rs motor good?
Old Oct 31, 2004 | 06:36 PM
kravdra's Avatar
Car Info: '99 Impreza OBS
As far as swapping goes, the hardest part is the wiring, physically it should go in without problems. I'd conntact LicMotorsports (a vendor here) www.licmotorsports.com They do swaps a lot, and r probably the best swappers in teh country (there in bay area, I don't know where your located.) I'd go over to the swap/transplant forum and browse a little to get a better idea. As far as how good the 2.5 is, I don't know (I have the weaker 2.2L), so I'll let someone else address that. It probably depends a lot on you though, I'd go test drive one, then you can see for yourself! GL
Old Oct 31, 2004 | 10:57 PM
Jesse00's Avatar
Car Info: 2002 Subaru TS
2.5RS(ej25) cant hold much boost if what it is what your asking. 6psi max i guess. This engine is not built for forced induction. If you want, you can either go for sti motor swap (sti is ej25t) or change the internals to suit turbo.
greenpoop
Jul 9, 2009 08:31 PM
FLIWRX
Engine and Drivetrain
Apr 30, 2007 01:27 PM
c279a
Oct 26, 2006 04:07 PM
Imprezer
Aug 17, 2006 12:00 PM
