QUestions on pullies
Old Nov 25, 2002 | 10:27 PM
A little is all there is. Pulleys are a VERY incremental increase in power. Thir benefit is really just addition by subtraction of rotating mass. You can get slightly (3-5) higher horsepower on a dyno, but it's low BFT$. But, it's not all that expensive and will do you some good, even if it won't make you noticeably faster. It's one of those things that helps add up with other things, but is all but useless by itself.
Old Nov 25, 2002 | 10:50 PM
stealth-wrx's Avatar
i have heard about idling problems with light pullies in conjunction with light flywheels. is it true
Old Nov 26, 2002 | 11:11 PM
Scubaru's Avatar
Car Info: MY02 GD WAGON, MY87 AW11
With both pulley and flywheel, I had to relearn how to take off from a stop again. Idle is a little low also.
-scu
Old Nov 26, 2002 | 11:17 PM
Lightening the pulley and flywheel together will make is easier to stall or "lurch" the car when upshifting. This is because the inertia of the rotating assembly is less able to cause the clutch plate to slip a little while the flywheel and pressure plates match speeds. It's also why the power of the combustion can spin it faster, making it more responsive. It's just another tradeoff for performance, like getting a harsher ride with coilovers in exchange for 70+ slalom speeds.
RALLYT-WRX
May 13, 2003 07:47 AM
RALLYT-WRX
May 5, 2003 05:43 AM
XyberX
Feb 5, 2003 12:03 PM
XyberX
Wanted
Jan 29, 2003 01:16 PM
TB RACING
Vendor Group Buys/Specials
Nov 25, 2002 01:57 PM
