QUestions on pullies
I am considering the pully found here https://www.i-club.com/forums/showth...p?threadid=233
but I am curious to the advantage/disadvantage to a single crank pully compared to the 3 pully sets I have seen in the past. Just want to make sure I don't miss out on a little extra power!
A little is all there is. Pulleys are a VERY incremental increase in power. Thir benefit is really just addition by subtraction of rotating mass. You can get slightly (3-5) higher horsepower on a dyno, but it's low BFT$. But, it's not all that expensive and will do you some good, even if it won't make you noticeably faster. It's one of those things that helps add up with other things, but is all but useless by itself.
I had a single under drive pulley on my Dak R/T. BAN SUVS is right, no big deal in terms of say 1/4 mile. Engine seemed to rev quicker. But by itself, you won't be shaving time off. Then again, several little tweaks here and there will add up.
/\rcanum
/\rcanum
Lightening the pulley and flywheel together will make is easier to stall or "lurch" the car when upshifting. This is because the inertia of the rotating assembly is less able to cause the clutch plate to slip a little while the flywheel and pressure plates match speeds. It's also why the power of the combustion can spin it faster, making it more responsive. It's just another tradeoff for performance, like getting a harsher ride with coilovers in exchange for 70+ slalom speeds.
XyberX
Feb 5, 2003 12:03 PM
Idle is a little low also.
