problem with car idling while moving
Old Mar 20, 2006 | 05:07 PM
mybluesubi's Avatar
Car Info: 97 Impreza Outback Sport (sorta)
If I'm cruising along and push the clutch in my car will idle really low and eventually die. If I'm sitting still it will idle just fine. I've hooked up an OBD2 code reader and it doesn't pull up any codes. Any help would be appreciated.
Old Mar 20, 2006 | 05:18 PM
impreza25rstn's Avatar
Car Info: 98 Impreza Hybrid
is it turbo'd? what mods do you have? My car does that but thats because I dont have my idel control sensor hooked up.
Old Mar 21, 2006 | 05:50 AM
AWDimprezaL's Avatar
clean your IAC (if your car is equipped with it) pull the large hose off the intake hose and keep the car from stalling, now spray carb cleaner in the hose for a couple minutes, while keeping the car running.
Lookinforwrx
Oct 24, 2013 04:51 PM
kmac-sti
Jan 6, 2006 02:54 PM
Mikoyski
Jul 29, 2003 06:55 PM
