oil in spark plug hole
Old Jan 20, 2004 | 05:23 PM
S'ko's Avatar
I have a 2k Outback, 2.2l engine.
I recently did a tune up and when I pulled the number 1 spark plug wire out, there was oil in the hole. what would cause this?
THanks
BW
Old Feb 1, 2004 | 11:51 AM
ImpSP's Avatar
Car Info: 1997 impreza L
If there is no oil on the surface of the head around the sperk plug hole, then you have, or have had a loose spark plug. If that is the case then what you see isn't oil, its a build up of burnt fuel. I had this problem and all I had to do was tighten the spark plug.
Vizzionz
Apr 7, 2007 07:57 PM
DetailAddict
Oct 21, 2005 03:11 PM
scoobie555
Nov 21, 2004 07:38 PM
Z Man
Jan 27, 2003 07:12 PM
Stickyfinguz
Jan 12, 2003 02:04 PM
