No acceleration EJ1.8L
Old Aug 5, 2004 | 09:07 PM
Myxalplyx's Avatar
Originally Posted by Ftlsubie
My 95 Subie EJ1.8L will not accelerate when I pin the pedal to the ground. At 2500 RPM it will shoot to redline. Any answers?
Is it an auto? If so, I'll be the first to say that your clutchpack in your tranny is toast. Anyone?
Old Aug 5, 2004 | 10:43 PM
Kostamojen's Avatar
NASIOC Slut
Clutch maybe if its a manual? Could you be more specific about what its doing? I also have a MY95 1.8, so I'm sure I can help
Old Aug 6, 2004 | 09:04 PM
Bad torque converter or, more likely, bad MAF, bad/fouled plugs, bad wires, etc... lastly, it may be a vacuum leak.
Old Aug 6, 2004 | 11:44 PM
Kostamojen's Avatar
NASIOC Slut
flashing CEL = bad. I concure with BAN SUV's, and there are a few other problems it could have too.
Old Aug 7, 2004 | 01:24 PM
Kostamojen's Avatar
NASIOC Slut
Mass Air Flow sensor, its in the intake track, like a 5" segment that has a plug in it.
Old Aug 7, 2004 | 11:32 PM
RoadSpike's Avatar
how do i find the vacuum leak? and thanks for the info on the MAF. can i find that at an auto parts store,or do i have to go to a dealer?
Leak test:
-Get yourself a can or wd-40 or similar.
-Then spray the vacuum lines down while the car is idling.
The engine will pick up rpm's when you find a leak.
Maf:
Not sure, but napa had one for my other cars so i suppose you can get one from them.
Old Aug 8, 2004 | 04:45 PM
rau's Avatar
rau
Something Custom
Talking
when i start the car the check engine light flashes on and off and the engine jitters and it idles very low but after a minute or two the check engine light goes off so i start to drive but when i press the gas pedal down the car moves like its getting push by an old lady anyway when i get mad thats when i pin the pedal to the floor the tach starts to rise slow and when it hits between 2000-2500rpm the car shoots to redline then the car rides fine but if i stop at a red light or anything i'll have to go thru the whole process again so if you or anybody can give me any advice i'd appreciate it thanks (oh yeah it's an automatic)
it kinda sounds like the same problem i had with my 1.8L auto. my tranny fluid hose burped all over 101, so when i would try to accelerate, it would just rev. not good on 101 south
Old Aug 12, 2004 | 02:30 PM
CatchMyDrift's Avatar
Car Info: 2010 Forester
I agree with BAN SUVS about the torque converter / also prolly your clutch.( If 5mt ) Before I had the tranny replaced in my 93, I had a bit of the same simptoms. My advise would be to take it into a local tranny shop and have them test drive it. ( Usually a free inspection )
IS2Scooby
Aug 19, 2003 05:39 PM
Imprezacrazy
Jul 16, 2003 10:23 AM
mr. m
Jul 13, 2003 07:05 PM
128d
Jan 30, 2003 09:31 AM
