no ac=more power?
Old Oct 14, 2003 | 11:10 AM
13Devils's Avatar
Car Info: 98 legacy gt
i asked this question a while ago and i was told that it was a bad idea to do so. you dont get any more power or revability at all (none thats noticeable) and when you do put the belt back on, you could have some problems. so when they told me that, i figured it wasnt worth it.
Old Oct 14, 2003 | 12:47 PM
whitelegacy98's Avatar
just dont use it and you wont have much power drain. Removing the belt just isnt worth it.
Old Oct 15, 2003 | 12:16 PM
13Devils's Avatar
Originally posted by audiofreak
ok thanks, what part of pa are u in
mountaintop, its between wilkes-barre and hazleton
Old Oct 15, 2003 | 04:11 PM
Kay95's Avatar
i have my belt removed now for a year and half
i just dont use it because i have a 1.8
and you do get revability and slight gain in HP, very slight
i am even considering removing the whole system because on a 1.8 you have no power at all when AC is on
Old Nov 5, 2003 | 10:09 PM
SuboobaruWRSEX's Avatar
Car Info: Viper ACR & H1
Take it all off. You will save rotational mass and general weight. It shaved like 50lbs off of my buddies DSM. And with the radiator type thing out it will provide more cooling to your radiator = keeping your car cooler = more power. It does require taking off all the hoses through the dash for total weight savings. 1 day to a weekend project (max). I only suggest this if you dont use your A/C.
Nick
Old Nov 5, 2003 | 10:58 PM
If you absolutely are prepared for life without AC, then go ahead and remove it for weight savings. But the rotational inertia and cooling loss are insignificant when the AC is off.
Old Nov 7, 2003 | 12:42 AM
No it won't. Removing all of the AC components will save some weight, but simply removing the belt will make a negligible difference in horsepower compared to just leaving the AC off. Negligible meaning like .01 horsepower.
04caliwrx
116
Jan 12, 2012 03:36 PM
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
blue blurr
Jun 22, 2006 02:53 PM
dyepball1
May 18, 2006 10:23 AM
dunnojack
Mar 13, 2005 11:02 PM
