NEed info
Old Jan 17, 2008 | 12:53 PM
96Imprez's Avatar
Car Info: 1996 Impreza Brighton bone stock sadly
NEed info
Does a swap between non tubo motor and a sti motor go over easily???
Old Jan 19, 2008 | 11:31 AM
gsxbusar1300's Avatar
There's many aspects to relate to your question. I've posted up a question on what I need to convert my 2.5RS to a WRX set up. The guys on here helped out a lot. Basically, you'll need all the parts of a donor STi or WRX front clip. Now, once you have those parts it's a matter of where your skills are. I've heard from friends that the physical labor (putting in the motor, tranny, etc) is not the worst thing in the world but I've heard that wiring is what gives people headaches. Overall, many ppl say its takes a lot of time and skill (and expensive too, so you'll probably have people tell you to just get a WRX). You should research some shops in WY or other forums =D Good luck!
Old Jan 19, 2008 | 12:15 PM
darkonion's Avatar
Chicks dig me. April Fool's!
That is correct gsxbusar1300. Unless you are planning to do it yourself, don't expect it to be gone cheaply. The cost of the swap (parts and labor) is almost as much as buying a used WRX.
Can it be done for cheap? Yes! But it requires you to have several things. Money, another car, and lots of patiences. I know East Coast Swappers can do it in under 6 hours, but they have done so many, and I assume that there are 4 or 5 people working on the car at once, is what contributed it to being finished so fast.
Old Feb 7, 2009 | 09:21 PM
scobytech24's Avatar
Car Info: 98 subaru impreza
everything sounds easy.. but if you have done the swap 3 or 4 times theirs no problem. basic translation.. the first time is hard !!
brucelee
Feb 18, 2011 05:38 PM
Mwizard
Jan 31, 2003 04:24 PM
WRX_Interested
Dec 27, 2002 12:52 PM
lou cypher
Nov 25, 2002 12:06 PM
