Low oil. How much is too little?
Old Dec 22, 2007 | 04:20 PM
redmomatt's Avatar
Car Info: 2004 Impreza 2.5 RS
Have a stock 2004 Impreza RS. Now I know running with low oil is a BAD THING. But, my question is how much is too little and to what degree does it harm the engine at various points? For instance, if I run a quart low for a month will it be worse than running 2 quarts low for a week, etc.? Also, does the quality of oil make up for lesser amounts; would a full high-end synthetic protect better with 3 quarts than dino oil would at 4?
I ask, because this has been bothering me for a year or two. About then, I neglected my engine a bit and didn't change the oil on time. I notice that when I did check it, it was below the low level on the dipstick and it took about ~2 quarts to refill. I know this was a VERY BAD THING. But, how bad? It seems to have been running fine ever since and I check my oil more frequently now. The only thing I think I have going for me is the fact that I've always used Amsoil 5W-30 / 0W-30 and Amsoil oil filters (though I don't change them but once a year / 25K miles - per mfg spec).
Should I start reading up on engine rebuilding?
Any ideas would be appreciated.
Old Dec 24, 2007 | 08:03 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Motors do not like low oil levels.
I have a motor in the shop now with a phat rod knock.
Pulled the dipstick...in the engine, not behind the wheel ...and guess what?
No oil present.
You are over-analyzing the problem....just keep the oil up to level.
Old Dec 24, 2007 | 08:39 AM
I_FLY_LOW's Avatar
Car Info: WRB 05 STi+04 Mini Cooper S
^^ and that would be mine dude just check your oil....and keep it up to level
Old Dec 24, 2007 | 09:20 AM
loccomoffo's Avatar
Car Info: 1995 GX Wagon AWD EJ18
There is no linear relationship between degrees of oil level and degree of engine damage. You need at least enough oil to keep the oil pump pumping as much oil as it’s designed to pump. When there isn't enough oil provided to the bearings they will simply run metal on metal and undergo accelerated wear. The most noticeable wear will happen in the con rod big end bearing which will start slapping. Bearings in the engine rely on there being enough oil in the bearing gap within a correct viscosity range.
Less oil in the sump means that it is circulated more frequently thus its exposed to higher temps more often and it is this which is the oils worst enemy. Heat oxidises engine oil thus breaking it down and thickening it up.
Synthetic oils like the one you use are much better at resisting this oxidation at higher temps thus they don’t need to be changed as often. Personally I use mineral oil and change it twice as often as this also gets rid of particulates in the oil which also damage the bearing surfaces (the filter doesn’t stop all of them).
Look after your oil level and change out period and your car will love you for it. My little 1.6L 4cyl car ran for 250,000miles (400,000km) on the original engine when I sold it 2 months ago and it was still running strong, all due to good oil maintenance.
If you want to read more, this’d be a good place to start:
Lube oil
http://en.wikipedia.org/wiki/Motor_oil
Hydrodynamic lubrication
http://webphysics.davidson.edu/facul...ubrication.htm
Enemies of lube oil
http://www.upmpg.com/lubricationnews..._deteriorates/
PS. just to stir , motors run on electricity, engines on heat
Old Dec 24, 2007 | 11:22 AM
redmomatt's Avatar
Thanks for the response and the great information. I will definitely look after it better.
In your opinion, would you think that I did permanent damage to my engine, or just perhaps accelerated its wear so that it would not last as long overall?
Old Dec 24, 2007 | 02:29 PM
NW OBS's Avatar
It's impossible to read an Impreza dip stick any way! It is a very vague idea of level at best! Just make sure there is some in there!
Old Dec 25, 2007 | 07:11 AM
loccomoffo's Avatar
Don't stress about it, as long as there was some oil left in there, all will be fine
It sounds like you change the oil out frequently enough so thats good, and definatelly the best way to keep wear to a minimum.
I remember my girlfriend once ran her engine dry of oil, she was wondering why the engine was reading soooo hot . After that even when i filled it with very heavy oil the engie had a very loud slap from the con rod big end bearings.
Old Apr 27, 2008 | 10:40 PM
HJC's Avatar
HJC
How's your car running now? I know this is an old thread but I came across it looking for rod bearings threads.
Don't mean to worry you but I ran my WRX's oil down so low there was none on the dipstick! Plus smoke was coming out of the tube! Worse was I was driving HARD before checking too. I put a little less than 2 quarts in. Ran fine after that.
Then......10,000 miles later, rod bearing went. Got the tick of death. Don't know if that's what lead up to it.
Old May 11, 2008 | 06:25 PM
dub81's Avatar
Whoa!! Thats living on the edge!!
laters,
walter
Old Jun 24, 2008 | 07:46 AM
redmomatt's Avatar
Just wanted to say thanks again and let everyone know that the car is still running ok. It's got about 73K miles on it and no problems yet. I'm certainly glad I've always used a high quality synthetic.
On a related note, I was wondering what standard oil consumption is for the NA engine. I've heard from various people that these engines have a reputation for burning a fair amount of oil. I've heard too that it's because these engines have pretty tight tolerences, and when cold they tend not to seal as well? This would fit with my perception that the engine startup noises are worse in the winter (until engine is at temp) and that I also burn more oil when it's cold.
Just wondering. Thanks.
Old Jun 30, 2008 | 10:05 PM
loccomoffo's Avatar
if the tolerances are tight then theyll also be tight when cold. my ´95 1.6L doesnt burn any oil and its done 160,000miles. if your car does lose oil then its either leaking somewhere or its getting past the piston rings as the rings or cylinder are worn. a compression test will lead you to this problem of a simple rev to see if you have blue smoke coming out the exhaust.
Old Jul 3, 2008 | 06:25 AM
redmomatt's Avatar
Thanks for the info. I checked the exahust, but didn't notice any apparent blue smoke. I think I will do a compression test, but also noticed some oily residue inside the tail pipe.
Is there a reason then, why I would have greater oil consumption in the winter than in the summer? Also, engine noises (before warming to temp) are also louder in the winter. Is this just because the engine oil is thicker and doesn't get to the parts as quickly?
Thanks again.
abakja1
Oct 9, 2013 03:16 PM
willl
Mar 16, 2007 04:16 PM
rollinDAwrx
Dec 3, 2004 12:50 PM
antdiesel3
Nov 8, 2004 02:56 PM
Fulloutpwr
Mar 6, 2004 01:21 AM
