are the intake tracts the same on all 98-01 rs's?
Old Aug 20, 2003 | 09:39 PM
Nope. Intake components for a 98-99 RS will not work with a 00-01. This is because the earlier cars had the MAF sensor inline with the intake tract, and were sort of a "roadblock" to using intakes- you could only modify it up to the Maf sensor, and needed to leave the rest of the tube to the throttle body the same. With the later MAP cars, however, you can do anything you want before the throttle body (some mods perform better than others) but it will still run ok.
If you are looking for a new intake, I would suggest the Cobb if you are willing to pay for it, or the PDM intake from PDM Racing if you are on a budget. The GanzFlow is also good on MAP cars if you can find a used one.
Old Aug 21, 2003 | 06:50 PM
Intakes meant for a MAF car won't work on cars with a MAP. The only way around it is to do some modifcation yourself- but what's the point of spending $125 on a do-it-yourself intake?
esousa22
Dec 7, 2011 11:08 AM
go1d1e
Jul 22, 2005 12:48 PM
dhlin
Jul 18, 2005 01:36 PM
sytran666
Dec 3, 2003 11:48 PM
