HELP w/CEL
Old Nov 25, 2002 | 10:32 PM
O2 sensor would be a good idea to try, and if it's more than 40k miles old, wouldn't hurt to replace anyway, might even increase your MPG. By bringing the car up to temp, it is running in feedback mode. When it is cold, it is using fuel/spark maps that are preset. It would possibly be your temp sensor if it were ok when warm but hard to start when cold. Unless the setup makes it think it is cold all the time, which could throw your fuel curves off by not being matched to the VE of your warm motor.
Ok, that may have been a little technical. Basically, get an O2 sensor. Cold help out and be worth it even if it doesn't solve the porblem. If it doesn't, try your MAP/MAF sensor, whichever you have. You can electrically test it yourself before replacing it. A well-intentioned dealer or independent shop can tell you how. After that, try resetting the ECU. If none of that works, break down and get a good diagnostic done. It's not that expensive in the long run.
Old Nov 26, 2002 | 09:35 PM
Yep, your probably right. I was thin ing about it earlier today and thermostat is a good possibility. As far as I know though, if you were to fluch out ALL of your green coolant, leaving only 100% water in your system, you could add any coolant you want. The red Toyota and orange GM stuff are both very good and very long lasting. However, if there were any green coolant left in your system, it would combine with the new stuff to make a kind of silicon sealant sludgy stuff, which can clog water jackets in sufficient quantities. Also, there is a slim chance Subaru used gaskets that may react funny with it. I had no problem with the Toyota coolant in my parents' Mercury, but that is not proof it will work for you. I expect it would, but I could be wrong.
Anyways, this might be a good excuse to do all the regular maintenance at once. Things tend to wear out in bunches for some reason anyway. Get new air, fuel, and oil filters, O2 sensor(s), coolant, plugs, and maybe think about tranny and brake system flushes. All of that can be done in your driveway in a couple hours, but if you have an automatic I'd take it to a mechanic or dealer to get a good flush. Make sure it's a flush, and not just a drain-and-fill if you do. Also, if you flush your own brake system, make sure you use only unopened containers, don't mix brands, and be VERY careful not to allow even the slightest hint of water into the system.
blkdout04
Sep 15, 2008 07:09 AM
new05wrx
Feb 17, 2006 03:13 PM
mrmodex
Jun 18, 2004 09:06 AM
MaVz
Jun 16, 2004 09:41 PM
esracer
Mar 16, 2004 11:56 AM
