help my car wont start
Old May 26, 2003 | 07:25 PM
joubtt's Avatar
Car Info: 00 2.5RS
I've had a similar experience and it was the spark plugs. It would start but stall within a several seconds. Only other thing may be a fuse.
Old May 26, 2003 | 08:55 PM
Does it start and actually run correctly for a sec, or just sorta fire but never enough to really keep going?
Old May 27, 2003 | 09:37 AM
I'm going to guess that you have a sensor failure somewhere. When you first start the engine, the ECU is 'running on faith.' It is sort of like reaching for the phone in the dark- you know where it's supposed to be, but it isn't always exactly how it should be. The ECU has pre-programmed fuel and spark curves it uses for a few moments before the sensors come on line, simply assuming everything is working. After a little bit though, it starts to read the sensors for input, and if one of them is off, it can result in malfunctions like stalling. Basically, it's going to have to be diagnosed by someone who is familiar with OBDII engines, unless someone else on the board here can give you a lucky guess.
Old May 27, 2003 | 09:16 PM
Originally posted by DDImpreza
got it back from the dealer it was the mass air flow sensor. i guess because i have a carbon fiber hood and the vent is open i have a foam filter on a elbow style intake it was getting real wet and the moisture or water screwed up the maf .. oh well thts my third one. its weird because the first time it went it was totally different problem.. i dont know not a mechanic... but thanks for the help and ideas.. oh yeah to solve the problem i took the plate off my stock hood and closed up the hole on the hood.
That should help. Your car is going to start running leaner and losing power though. You should switch to a true cold air intake if possible.
Old May 28, 2003 | 03:10 PM
Cobb's intake is the best, but it's expensive and has to be adapted to MAF cars. For 98 and 99s, it's really best to just remove the silencer from the intake and stick with stock. You'll still hear that intake growl at high RPM, and you don't gain much power with an intake anyway.
STIKRAZY
May 18, 2009 01:20 AM
muskatomas101
Dec 2, 2007 04:30 PM
jeanna0221
May 1, 2006 06:58 AM
krillz
Jul 2, 2003 04:37 AM
KnightRider
Dec 31, 2002 04:24 PM
