Need Help Car Wont Start
Old Dec 1, 2007 | 10:02 AM
muskatomas101's Avatar
Car Info: 05 STI FM S366
Ok so here is what went down. Swapped my stock turbo out for a rotated 3076 turbo.
Pulled the intake manifold with all the clips ext. cleaned the gaskets off and put new ones on. While the car was apart i put new ngk one step colder plugs in. new oil and coolant. got everything bolted up last night re plugged in the fuel pump, and flashed the limp/base map to the car. Went to start the car, turns over but no fire... I’m kind of at a loss where to start any ideas would be great!
here are mods
2005 STi
with Cobb AccessPORT V1
3076 turbo with .82 a/r housing
3" down pipe
perrin rotated up pipe.
44mm wg
perrin big maf intake filter
perrin fmic with perrin blow through boost tube with an hks bov weld to it before map
hks Ti carbon 3" exhaust
850 pe injectors.
Old Dec 2, 2007 | 04:30 PM
wrxpsi's Avatar
Car Info: 06 Steel WRX
no start
when you flashed the base map did you remember to unplugged the green connector under the dash?
STIKRAZY
May 18, 2009 01:20 AM
jeanna0221
May 1, 2006 06:58 AM
krillz
Jul 2, 2003 04:37 AM
DDImpreza
May 28, 2003 03:10 PM
KnightRider
Dec 31, 2002 04:24 PM
