Car WOnt Start!!!need help plz
Old May 9, 2009 | 03:23 PM
STIKRAZY's Avatar
Car Info: STI 2004 subaru
Exclamation Car WOnt Start!!!need help plz
ello, in some crazy turn of events i ran my car out of gas, 04 STI, im trying to start it and it seems likes its not firing. (ex: seems like i have no spark) was wondering if running it out of gas may have tripped something that needs to be reset. i tried reseting the codes but every time i try and start it again it pops up with 6 codes : low ignition voltage, o2 bank 1, o2 bank 2, neutral switch low voltage, and a couple more. anyone have any help it would be nice TY
Old May 9, 2009 | 04:53 PM
soggynoodles's Avatar
It might take a few turns of the motor to get things fired up. When you turn the key to the on position do you hear the fuel pump?
Old May 9, 2009 | 06:44 PM
MonsterGC's Avatar
Car Info: 2000 2.5rs
charge the battery and since you ran it till you run our of fuel it might take a more than a few turns to turn over
Old May 9, 2009 | 07:57 PM
STIKRAZY's Avatar
ive been cranking it for sometime, and i did think it may have been the battery at first so i replaced it. i popped the plugs out and they had some unburnt fuel on them, thats why im thinking its not firing. but ill try it a couple more times
Old May 9, 2009 | 08:19 PM
MonsterGC's Avatar
if the plugs are fouled replace them spark plugs are pretty cheap
Old May 9, 2009 | 11:44 PM
STIKRAZY's Avatar
and and yes to noodle man the fuel pump is cycling.
Old May 10, 2009 | 12:15 AM
possibly sucked up all the crap off the bottom of your tank and clogged the injectors??
Old May 10, 2009 | 04:04 PM
STIKRAZY's Avatar
that might be a good thought, ima clean the injectors and try a couple more things out. if anyone knows why the ignition might not be firing plz tell id like to cover all my basis' before i decide to pull the motor .
Old May 11, 2009 | 09:03 AM
you have a spark tester aka put it on teh side of the block and turned it and didnt see the spark correct?
you arent pumping the gas pedal right?
Old May 18, 2009 | 01:20 AM
code3suby's Avatar
Car Info: 97' Dodge Cummins and an RSTI thingie
I would definitely find out if you get spark. There's a few things that I think it could be:
Clogged Fuel Filter - junk at the bottom of the tank totally clogged it
Clogged Injectors - junk go to the injectors
Fuel pump - running fuel pumps without a load can cause it to burn out (found that out the hard way in my old toyota truck lol
I would replace the fuel filter (in tank, ouch)
Spark plugs
and this might be a good time to upgrade to a walbro fuel pump
muskatomas101
Dec 2, 2007 04:30 PM
krillz
Jul 2, 2003 04:37 AM
DDImpreza
May 28, 2003 03:10 PM
KnightRider
Dec 31, 2002 04:24 PM
