help my car is running on 2 cylinders
Old Aug 17, 2004 | 12:59 AM
mrmodex's Avatar
ok so i am driving to school today and the car is sluggish then the cel comes on and then it starts blinking now i am running on 3 cylinders i can still move at 80 then when i gewt off the exit it is running on 2 i can barely move
and it is bellowing out whitish blue smoke out of the muffleri get to shcool i take out the spark plugs and i see that the front left and right rear are soaked in gas this has happened 4 times before every two weeks it seems i take out the plugs let it dry for a few hours and it starts up fine does anyone have any idea as to why this would happen please help
Old Aug 17, 2004 | 03:31 PM
RoadSpike's Avatar
Blue smoke is oil. Perhaps you have a bad ring and its fouling the plugs. Or your plugs could just be very worn, i'd replace the plugs and take a look for carbon build up.
Old Aug 17, 2004 | 07:07 PM
mrmodex's Avatar
they are brand new plugs that i put in when this happened the first time and the smoke is from the fuel that is unburnt i also compresion tested it and they were all at 180-185
Old Aug 17, 2004 | 10:02 PM
Misfires? Replace your ignition wires, and test your coils.
Old Aug 17, 2004 | 10:07 PM
mrmodex's Avatar
i will try that next but i checked them and they are firing fine
Old Aug 17, 2004 | 10:11 PM
Either you're not getting spark or your injector(s) failed open. Engine faults are fuel, air, spark, or gasket related. You have fuel, and head gasket failures would allow oil and/or coolant in the chamber but it would fire (and you'd be losing oil or coolant). Not a lot of ways to screw up air flow besides vacuum leaks, but then it should still run, although badly. So, somethings not working. I'm fairly certain it's weak spark or way too much fuel. What's your spark plug gap?
Old Aug 17, 2004 | 10:29 PM
mrmodex's Avatar
i dont know i will check in the morning
Old Aug 18, 2004 | 05:41 PM
Any progress?
Old Sep 5, 2004 | 05:20 PM
Slowgoin22's Avatar
Car Info: 95 Legacy Sedan
Maybe you can tell me what size engine and what car and year it is? Also have you scanned the computer for freeze codes?
Subaruski42o
Jun 27, 2005 09:20 PM
Subaruski42o
Jun 25, 2005 10:54 AM
rugby9
May 18, 2005 08:26 AM
EtchyLives
Jul 19, 2003 04:11 PM
