HELP: ASAP what the GAP on 2.5RS plugs?
Old Oct 13, 2005 | 05:39 PM
Dynapar's Avatar
as the title says? need to get this car a MOVIN! put new plugs in and wotn idle. my guess is bad gap. but i dont know the specs.
Old Oct 14, 2005 | 11:41 AM
Checkpoint's Avatar
Car Info: 00 RS
I think the gap is about .43. But that shouldn't be the problem at all if the car won't idle. There is something electrical going on with the motor. Or maybe its busted. Did you ever over heat the car? Or is there any codes. Also, check the ingnition coil thingy. Make sure there aren't any burn marks where the wire make contact with the coil. If there are, then you are having a grounding problem. Pull the plus and wires out of the car and stand infront of it while someone turns it over. That will let you know if your getting spark or not. Sounds to me like you have a fuel problem.
Miotch www.cp-racing.com
CynicalCS84
Jan 25, 2011 09:01 AM
Bagin,DVS
Mar 25, 2008 10:22 AM
ROSSCAD
May 7, 2005 05:11 PM
Stime
Feb 2, 2003 12:37 PM
thetikler1
Dec 12, 2002 08:31 PM
