cams & cam gears for the 94 EJ18
Old Sep 21, 2003 | 03:10 PM
rau's Avatar
rau
Something Custom
Question cams & cam gears for the 94 EJ18
does anyone know of a manufacturer who makes cams that pass CARB testing that will fit the EJ18? im getting kinda desperate and am about to just get DOHC 2.5 heads and swap those on....if they fit. or just throw in the stock cams from the SOHC 2.5.......if those fit. or maybe i should just go the easy boosted route and throw in a whole EJ20T......
i dont know about all that, but i do need cam help.
thanks
Rau
Old Sep 21, 2003 | 07:26 PM
No such thing as CARB legal cams, and I have never run across Subaru specific cam gears.
Old Sep 21, 2003 | 11:55 PM
Kostamojen's Avatar
NASIOC Slut
There are no aftermarket cams for EJ18's. Theres basically no aftermarket support for EJ18's period. You would have to have everything custom made. Its not really worth it anyway, as the EJ18 heads are horrible. And no, any modification to cams would not be CARB legal.
What is legal, is swaping in a newer engine (but a JDM engine is not legal)
Old Sep 23, 2003 | 07:59 AM
Impreza_WRX_STi's Avatar
Car Info: www.autoquoteresearch.com -- 02WRX
What about EJ20,22,25 cams? would they fit. Maybe..
Max
Old Sep 24, 2003 | 04:15 PM
Kay95's Avatar
http://www.paeco.com/
take off your heads with cams and give these plp a call
if you have the money they can port and polish too
for less than $1500 you can gain more than 50 HP
Old Sep 26, 2003 | 11:02 AM
q
I have had Paeco's catalog coming for about ten years, I ordered an ignition from them but they sent me one for an older subaru which required a distributor. Has anyone else got parts from them?
Max
Old Sep 26, 2003 | 03:23 PM
Kay95's Avatar
i emailed them for a catalog so i can so just what they have on hand for my suby
Old Sep 29, 2003 | 11:48 AM
rau's Avatar
rau
Something Custom
so since there is no such thing as a CARB legal cam, what about the EJ25 SOHC cams? or should i just switch the whole heads? ( after porting/polishing, of course )
Old Sep 29, 2003 | 01:30 PM
Kay95's Avatar
do you live in a place with smog testing?
because depending what state it is it might not be as strick as others and you could still pass with cams just not that aggresive a cam
Old Oct 2, 2003 | 12:40 PM
rau's Avatar
rau
Something Custom
i live in redwood city, 30 or so miles sout of SF, and i just got my car smogged in may so i have a year and a half........im just afraid of getting pulled over and having them smog me like they did my brother............90 240sx w/ stroked RB26DETT
Old Oct 2, 2003 | 01:41 PM
Kay95's Avatar
oh in that case you should swap to be legal
even if you change heads that could make you illegal because you would put out more than the specs that are for the your car
brucelee
Nov 7, 2008 03:30 PM
Drimmie
Aug 14, 2007 10:17 PM
Imprezer
Latest i-Club Reviews, Features, and Articles
Jul 25, 2006 05:40 PM
rau
May 11, 2004 06:48 PM
sUbEe
Aug 25, 2003 07:12 PM
