Adjust clutch or replace?
Old Jul 19, 2007 | 10:31 PM
thebetguy's Avatar
Car Info: 2.5i N/A
I went autocrossing last weekend and now my clutch grabs a lot farther out than it used to. Where can i adjust this or should i just replace... if i have to replace it, is it covered by warranty? i have an 06
Old Jul 20, 2007 | 09:50 AM
kaotik78's Avatar
Car Info: 07 Subaru Impreza N/A
Autocrossing, so you were beating on the car? Im sure that's probably what the dealership will say to you. All depends on what they find when they take the trans apart, clutch condition, pressure plate etc etc. It's an 06 and the clutch is already on it's way out though, that sounds like some serious beating? Bring it by and let em take a look at it.
Old Jul 22, 2007 | 05:37 AM
thebetguy's Avatar
Car Info: 2.5i N/A
is the clutch even covered by the warranty? If not i'll do it myself
Old Jul 22, 2007 | 09:58 AM
zavier's Avatar
Car Info: 2007 Impreza 2.5i
i believe the clutch is considered a wear and tear item...so i doubt it'll be covered...and if it was you burned your out way to fast...they prolly wouldn't cover it because they wont cover any part broken by "racing"
Old Jul 22, 2007 | 03:00 PM
thebetguy's Avatar
Car Info: 2.5i N/A
can it be adjusted though? in my friends integra he adjusts it all the time down by the pedal.
Old Jul 28, 2007 | 12:29 PM
kaotik78's Avatar
Your refering to the slack adjuster (similar to what's on a air brake system) It's a rod that adjusts the hydraulic clutch. It does not adjust the clutch per-se but the amount of travel needed to engage/dis-engage the clutch based on wear.
keirnna
Jan 27, 2005 01:13 PM
ommmjido
Dec 21, 2003 05:29 PM
Shwag
May 24, 2003 03:24 PM
Subaru930
May 19, 2003 09:25 PM
bedweaselwrx
May 19, 2003 01:40 PM
