2001 2.5 Hesitates when accelerating.
Old Nov 17, 2003 | 05:13 PM
Br1t1shguy's Avatar
Car Info: 02' WRX
Check plugs and wire resistance. Could also be igniton coil/ignitor. Is the car warmed up when it does this?
Old Nov 17, 2003 | 08:03 PM
awns729's Avatar
Car Info: want a WRX
id check the wires next...is it giving you a cel? if it ever does its probably best to stop driving immediately...something happened to my moms highlander...she drove 30 miles w/a CEL and a chewed up spark plug wire...turned into a costly problem, and a major inconvinience. good luck
Old Nov 17, 2003 | 08:16 PM
AzN121184's Avatar
Car Info: civic
awns how come at 1200 u have an avatar??
Old Nov 21, 2003 | 06:18 AM
SUBARU_TECH's Avatar
you need to get the latest reflash for your ecu.and at the same time you will need a new air/fuel ratio sensor.if you reflash without the new sensor,the orignal sensor will fail.go to www.mysubaru.com and check to see if your car is available for the recall on this.
edzwrx
Jul 18, 2013 09:14 PM
amtrac24
Jan 18, 2005 08:46 AM
TheWickedWRX
14
Jan 26, 2004 07:02 PM
jsoiza
Aug 1, 2003 09:12 AM
