Acceleration hesitates, then surges
Old Jan 23, 2004 | 10:49 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
sounds like your boost might be spiking....not sure tho
Old Jan 24, 2004 | 11:14 PM
Wingless Wonder's Avatar
Origami posted by TheWickedWRX
Ross Racing Pistons, Paeuter Rods, Turbo XS FMIC, Injen CAI, Turbo XS up/down pipe, hks hi-power exhaust, turbo xs u-tec, short shifter, rota subzero rims, engine grounding kit, hks type 1 turbo timer.
No engine management for these mods?
EDIT: It helps to use an appropriate Subject line for your thread.
Old Jan 25, 2004 | 10:48 AM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
CEL flashing would indicate knock, do you have a boost gauge? are you over boosting above your dyno tuned setting? Perhaps you were tuned in the summer a little close to the edge and now with the colder temps your boosting a little more than expected?
Perhaps you should borrow a laptop and run some logs!
Mike
(510) 487-4447
www.mpjperformance.com
www.gb-motorsports.com
Old Jan 25, 2004 | 11:26 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
are you running 18lbs on stock internals constantly....recommended max on stock is around 15.5-16lbs...
Old Jan 26, 2004 | 12:16 PM
mmboost's Avatar
Well, time to stop complaining, and like Mike said, start logging. If you don't see any visually identifiable hysical problem you gotta find out what the computer's responding to. Go to that shop you spoke of and see if you can rent/borrow a logging tool... or make a friend on i-club
jason
Old Jan 26, 2004 | 07:02 PM
DarkAngel's Avatar
Its prob your spark plugs or your coil pack. I had the same problem and it was a bad coil pack and its fine now. Basically you are running on 3 or even 2 cyl and its not that great for your car. It was also same with mine. It would be fine for a while than it would happen again. Its while its not jerking around the sparks are actually fireing but very weak, bc they are dirty or just bad. Hope that helps
edzwrx
Jul 18, 2013 09:14 PM
aloose
26
Mar 20, 2006 12:09 PM
amtrac24
Jan 18, 2005 08:46 AM
lew thomas
Nov 21, 2003 06:18 AM
