1996 Impreza 2.2- Need more power!
Old Dec 27, 2004 | 01:20 PM
scoobsport98's Avatar
Car Info: 98 Impreza Outback Sport
This might inspire something... I also have a 2.2 automatic- I considered not modding it, but said what the hell
intake:
https://www.i-club.com/forums/showth...eld+fiberglass
headers/exhaust:
https://www.i-club.com/forums/showth...ers+custom+cat
suspension:
https://www.i-club.com/forums/showth...ht=lowered+OBS
I also have a perrin pulley, 8.5mm plug wires, and iridium plugs, which I believe were all worth while- esp. the pulley.
Old Jan 8, 2005 | 03:58 PM
Dynapar's Avatar
i have a very similar car. 1995 impreza LX 2.2l Automatic.
the intake is always a fun option it wont do much (especailly at low revs) but it sounds great around 3k. i have done this to my car and you can keep the stock MAF sensor and intake hose deally. you just need to buy or fabricate a piece that will bolt to the MAF sensor and then will mate with a coen filter. very easy.
to make it just pull off the airbox for a min trace around the MAF sensor on some cardboard. make sure to include bolt pattern. then use the cardboard to trace th pattern onto some aluminum or steel. cut it out quick cut out a 3" hole in the middle. weld or jb weld on a piece of 3" pipe and whalla you got a intakle adapter.
or you can buy one on ebay for $15 + $15 s/h
for quick horses i would reccomend the Unorthodox racing under drive pulleys. not too pricey for the small gain your looking for.
Old Jan 9, 2005 | 05:08 PM
Dynapar's Avatar
i posted how to do the DIY mods on this board
Old Jan 15, 2005 | 10:22 PM
scoobylvr's Avatar
Car Info: 1998 Impreza L EJ22
You can buy one at Autozone for 14.99, it doesn't fit quite right, but you can just use the two corner bolts and it works pretty good.
04Impreza
Jul 16, 2010 10:12 PM
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
jakeg
Mar 26, 2010 10:38 AM
dunnojack
Mar 13, 2005 11:02 PM
I3eXa
Apr 4, 2003 12:41 PM
