WRX stage 2... need tune?
Old Oct 30, 2007 | 12:24 PM
Subistrong's Avatar
Car Info: 2006 subaru impreza wrx
Exclamation WRX stage 2... need tune?
im looking 2 buy the stage 2 cobb kit but i am reading alot about needing 2 bore out the wastegate or you will get boost creep and what not. just wonderin if i will have any problems in the long run with buying this kit for my 06 wrx
Old Oct 30, 2007 | 03:32 PM
cannibal869's Avatar
Car Info: 2004 WRX
bore out the what???
I dunno if the 06's are different, but the 02-05s I believe have been running Cobb stage 2 without problems
Old Oct 30, 2007 | 04:39 PM
midnitewrx's Avatar
engine management will solve this. get an ACCESSPORT
Old Oct 30, 2007 | 05:01 PM
Subistrong's Avatar
well duh stage 2 is TBE with accessport. with the sti's i guess the wastegate hole is 2 small on the turbo and it creates boost creep under high rpms and when your boost creeps higher than stock your ecu will freek out and cut out. i dont know if the same problem will occur on the new wrx's because they have the sti block but the wrx turbo... anyone got the stage 2 cobb on their 06-07 wrx's? i need 2 know if its worth the 1800 bucks
Old Oct 30, 2007 | 05:04 PM
Subistrong's Avatar
https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/why-did-do-boost-creep-44825/ thats what made me worry
shaggadelic
Nov 3, 2012 01:39 PM
02whitebugeye
Jan 26, 2010 10:08 PM
HungrySTI4V8
14
Sep 27, 2008 02:14 PM
dustythedeal
Mar 12, 2008 01:02 AM
