What is this?? Green Fluid, Pics inside
Old Jun 26, 2011 | 11:46 AM
Volkey's Avatar
Car Info: A Dirty Car
I was changing my oil on my 06 WRX and while removing my oil filter, I knocked off a small tube which looks like it goes into where my filter does. Lots of green fluid dumped everywhere (a good 4 quarts atleast)
What is this fluid, and how do i replace it??
Old Jun 26, 2011 | 12:15 PM
HammsBear's Avatar
Car Info: '03 WRX sedan PSM
Could be coolant, that is sometimes green, but I don't know what that tube is. I would check the coolant level
Old Jun 26, 2011 | 12:24 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
That is a coolant hose and if it fell off, you should replace it and both clamps.
If you don't feel comfortable doing it, tow it to your favorite shop.
If yo don't burp the cooling system correctly, you'll frag the engine.
Old Jun 26, 2011 | 12:52 PM
OneManArmy's Avatar
General Pimpin'
Just quoting for emphasis and because it makes me feel cool when I quote Paul....
He's right on all accounts. I'd have those pinch clamps swapped out for the screw type as well. I don't trust those things and since you're in there... do it. And if you didn't know that was coolant I'd have the car towed to a shop and have them fix it.
Short hand.... The ONLY fluids in your car.
1. Gas: Clearish and intentionally smells like... well gas. Not flammable but the vapors are.
2. Coolant: Green.... smells like candy. SUCKS. Stuff gets everywhere and is sticky and gross.
3. Oil: If it's black you went to long. Lord willing it doesn't ever have metal in it.
4. PS fluid. Yours should be a slightly brown clearish color.... I think. And it's VERY flammable.
5. Brake fluid. Yours should be a slightly brown clearish color... Can be other colors but yours shouldn't be.
6. Gear oil: Color fades but generally it's stinky and if it's brown and you can't see through it it's bad.
7. Tranny fluid. Red.
So in really short hand.... the only green fluid in your car is coolant.
Old Jun 26, 2011 | 05:21 PM
Volkey's Avatar
cool thanks guys, replaced clamps and filled coolant system back up and everything is back to good condition.
Ryan
JMeltzer4
Aug 17, 2010 07:23 PM
fourZero
Jul 5, 2009 08:11 AM
jinorazi
May 22, 2008 04:52 PM
jasno999
Feb 9, 2004 04:49 PM
addictarmy
Sep 24, 2003 11:47 AM
