Turbo Spooling sound...
Old Mar 13, 2007 | 08:02 PM
impreza-tux-121's Avatar
Car Info: 2006 Impreza WRX Sti/Hawkeye
Okay. I hooked up a Hallman Boost Controller but I set it to stock. The thing that it spools up ALLOTT quicker then stock but when it does spool up to full boost at low RPM it sounds like either the BPV can't take all that boost. Makes a sound like spooling up but it sounds kinda like air leaks or something...
Old Mar 16, 2007 | 10:08 AM
wimprezax06's Avatar
Car Info: WRX --> RX-8--〉E93
dont turn it too high do you have a boost gauge? keep it at the safe boost. and do you have a DP, dont give too much boost and your turbo cant get the air out.
Old Mar 18, 2007 | 06:24 PM
yeah when racing at high REVS the boost gauge reads stock. its good but at low RPM and high gears it reads 1.1Barr
Old May 29, 2007 | 07:47 AM
BlaKKStaRR's Avatar
Car Info: WRX 2007
thats almost 18psi....18 is like 1.2bar.
and 18 psi is waht im running and im stg 2
and u got a stock downpipe?? i say turn the boost down before u overwork the turbo
Old May 30, 2007 | 10:34 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
Another possibility that is unlikely but possible. In my car, under high load, i was getting an uppipe to turbo exhaust leak. It was very small and only under high exhaust pressure and sounds like a whistle. Dealer eventually found and fixed it
Old May 30, 2007 | 10:57 AM
03_Impreza_Al's Avatar
Your not supposed to be at full boost at lower RPMs...
Old May 30, 2007 | 12:28 PM
charlesj's Avatar
Staff Member
Car Info: 06 STI
that depends on what is considered lower rpms. Boost tapers at high rpm, so highest boost levels should be seen in the midrange from as little as 3k rpm
Old May 30, 2007 | 12:39 PM
sti4j0n's Avatar
Car Info: '05 sti
same thing happened to me when i got a stage2 from FLI
not that they did a bad tune or anything, but i had a boost leak when they tuned it, and i fixed it later... so something about the HWG map from COBB fixed it
1) try slipping the gas pedal down to the matt (slowly getting it to like 12-15 lbs then stabbing it..
2) then just try matting it from 2400 rpms in 5th
when i just matted it from 2400 in 5th it kinda bogged for a sec... then hit about 21lbs for a sec then tapered quickly (5800 rpm) to 16 then held at 17(till red line)...
then i got the HWG map and it just went to 17lbs and held...
hope this helps..
Old May 30, 2007 | 04:03 PM
vietpunk916's Avatar
Car Info: AP1 S2k
your car is gona blow up. heres the step to not blow up your car and have the whp u want:
1) remove mbc and ebay or trash it
2) order cobb or tatrix cable
3) protune
4) ship mbc to a noobie.
Old May 31, 2007 | 09:31 AM
sti4j0n's Avatar
Car Info: '05 sti
how much for the mbc
Old May 31, 2007 | 09:48 AM
KOSTI's Avatar
Car Info: Black On Black Wingless 05 STI
3) protune
I'd say that just about sums it all up!
wrecks43
Feb 1, 2007 10:05 AM
Hurucan
Aug 28, 2006 12:15 AM
SubyWRXdude
May 8, 2005 03:30 PM
rustokman
23
Sep 5, 2004 10:35 AM
Silverbullet04
13
Jan 15, 2004 06:45 PM
