STI Turbo limits
Old Mar 7, 2005 | 04:13 PM
NJ Dino's Avatar
Car Info: ATR Catback, HKS Downpipe, Injen CAI, 17x7.5 Rota Subzeros/Falken Azenis, Tein HA's, Apexi-SAFC,
STI Turbo limits
Just out of curiosity, how much boost can the stock STI turbo run?
Old Mar 7, 2005 | 05:33 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
15 psi no 35 psi.
Old Mar 8, 2005 | 06:52 PM
NJ Dino's Avatar
15 PSI? thats it? how is that so? a stock WRX will run 16 all day?
Old Mar 9, 2005 | 11:15 AM
XkrazyAsianX's Avatar
Car Info: SGM 135i
i dont think it's 15 psi ...
Old Mar 9, 2005 | 12:35 PM
aloose's Avatar
Car Info: 2002 Sooby WRX (not runing right)
It is a 2.5 Litre engine with performance components. You dont need a ton of boost to achive 300hp
My 1965 lotus elan has a straight 4 and is puting out 294hp none asperated. runing dual webber's so I would hope a newer technology engine with fuel injection can achive 300hp without 900lbs of boost.
my 2 pennies
Old Mar 9, 2005 | 03:00 PM
meilers's Avatar
Not even close. A stock WRX (not STI) will top out at 14 and will be there for about 2 seconds and then drop to 13; furthermore boost in 1, 2, and 3rd gear is ECU capped at 12psi.
NJ Dino's Avatar
I hear ya on that but I dont really care what power the STI makes with that turbo> I am jsut curious as to the actual flow limitations of the STOCK VF39
Old Mar 9, 2005 | 03:47 PM
NJ Dino's Avatar
dude I dont konw what your talking about but...before i even had the mods, with a greddy boost gauge to monitor it. I was making 14 psi in all gears and almost 14 in 1st. I dont know, I have heard of all different cars making different boost. But right now I am running 16 with my mods and it was holding with little drop twards redline. now wiwth the header and uppipe the boost falls off a little before redline, but its fast all around. Just wondering if ANY ONE knows how much boost people are running on VF39s.
Old Mar 9, 2005 | 05:17 PM
EROCK's Avatar
Car Info: 04 STi
I was running 17.5 psi on my vf39 for about 8 months with no issues.
Old Mar 9, 2005 | 09:12 PM
meilers's Avatar
Pay attention. You are posting in the WRX thread, not the STI thread. I was discussing the WRX stock turbo, not the STI stock turbo. Perhaps you'd get better results if you had thought to post to the correct forum.
Old Mar 10, 2005 | 05:48 AM
NJ Dino's Avatar
look dude, Im not trying to start a flame war here. I shouldnt have to post this in an STI forrum. Maybe results would have been a little quicker if I did. People ask all the time about different turbos, thats what this is isnt it? A different turbo. I dont care what kind of power it makes on an STI. And if I recall, I dont remember asking about a stock WRX turbo, though I appreciate the extra info. Anyhow, there are plenty of people running this among many other turbos on WRX's wich is why I posted here. Just my 2 cents. Thanks for the concern though. Next time I will try to post in the "correct forum"
Old Mar 10, 2005 | 04:04 PM
meilers's Avatar
Sorry, I didn't mean to jump on you -- I'm just not certain exactly what you are asking. Do you want to know how much boost you can run in the stock STI turbo (VF34/39) when it is installed in a WRX? If that's the case, the answer is easy -- there is a fuel cut at 19psi, and in stock trim in the STI the turbo runs 15.5psi (1 bar). I've heard of attempts to run over 19psi with a VF34, but that requires a ton of supporting mods (fuel rail, injectors, fuel pump, ported wastegate, ECU tuning) and would probably be a short run before a rebuild. I think the EJ20 block can only supply enough fuel for 16psi; anything over that without fuel supply mods would cause some dangerously lean conditions and detonation.
There is also have an "aftermarket turbo" forum which is where most of the turbo-swap related discussions happen.
Old Mar 10, 2005 | 04:23 PM
Rocket Man's Avatar
Car Info: it's nice
the turbo will house 350 horses. The amount of boost you're willing to go is up to you. I'd be more concerned about how much your block can house.
