STI Turbo limits
Car Info: 2002 Sooby WRX (not runing right)
It is a 2.5 Litre engine with performance components. You dont need a ton of boost to achive 300hp
My 1965 lotus elan has a straight 4 and is puting out 294hp none asperated. runing dual webber's so I would hope a newer technology engine with fuel injection can achive 300hp without 900lbs of boost.
my 2 pennies
my 2 pennies
Originally Posted by NJ Dino
15 PSI? thats it? how is that so? a stock WRX will run 16 all day?
Car Info: ATR Catback, HKS Downpipe, Injen CAI, 17x7.5 Rota Subzeros/Falken Azenis, Tein HA's, Apexi-SAFC,
I hear ya on that but I dont really care what power the STI makes with that turbo> I am jsut curious as to the actual flow limitations of the STOCK VF39
dude I dont konw what your talking about but...before i even had the mods, with a greddy boost gauge to monitor it. I was making 14 psi in all gears and almost 14 in 1st. I dont know, I have heard of all different cars making different boost. But right now I am running 16 with my mods and it was holding with little drop twards redline. now wiwth the header and uppipe the boost falls off a little before redline, but its fast all around. Just wondering if ANY ONE knows how much boost people are running on VF39s.
Originally Posted by meilers
Pay attention. You are posting in the WRX thread, not the STI thread. I was discussing the WRX stock turbo, not the STI stock turbo. Perhaps you'd get better results if you had thought to post to the correct forum.
Sorry, I didn't mean to jump on you -- I'm just not certain exactly what you are asking. Do you want to know how much boost you can run in the stock STI turbo (VF34/39) when it is installed in a WRX? If that's the case, the answer is easy -- there is a fuel cut at 19psi, and in stock trim in the STI the turbo runs 15.5psi (1 bar). I've heard of attempts to run over 19psi with a VF34, but that requires a ton of supporting mods (fuel rail, injectors, fuel pump, ported wastegate, ECU tuning) and would probably be a short run before a rebuild. I think the EJ20 block can only supply enough fuel for 16psi; anything over that without fuel supply mods would cause some dangerously lean conditions and detonation.
There is also have an "aftermarket turbo" forum which is where most of the turbo-swap related discussions happen.
