Question about habit learning ECU...
Old Jul 27, 2004 | 10:39 PM
RoadSpike's Avatar
supposedly there is a method to make the ECU pick up points faster so your ignition is fully upped.
There is a number the ecu uses to adjust your ignition timing through some complex math curve. The higher the number the more advanced your timing will be.
So... the method....
According to a few of the real guru's with a cleared ecu i believe you take the car up to low-moderate speeds with the rpm at like 2500rpm and apply 1-2psi of boost by accellerating and braking lightly for about 10-15 seconds. This should put the number at the maximum.
There is a thread on this just search for it.
Oh and i should mention with normal driving the ecu is quite slow to up your target iginition advance number but i think it will drop easily.
Old Jul 28, 2004 | 12:24 PM
RoadSpike's Avatar
Originally Posted by dus10
I know about the Vishnu reset and that's why I'm asking the question. If you run a tank of crappy 91 then on the next tank you run 94 do you have to perform the Vishnu reset in order to get the ECU to advance the timing or will it do it on its own?
According to vishnu the ECU is pretty slow at picking up the timing with normal driving. If you want the immediate power i would do the reset. Sounds to me like it would take most of a tank of gas to up the timing the way Vishnu put it.
newyorkreload
Meetings, Events and Group Streaking
45
Jul 16, 2009 04:42 PM
Vishnu
Jan 4, 2009 07:35 PM
mmboost
Oct 9, 2007 11:48 PM
Sky92x
Feb 23, 2007 11:14 PM
suby_dude
Apr 22, 2003 10:45 PM
