Problems w/ the STI
Old Jan 30, 2004 | 08:25 PM
midnightwrx's Avatar
Car Info: 2004 subaru sti
Problems w/ the STI
What would cause an STI to misfire in cylinders 2 &4, spit oil out the BOV and smoke come out of the exhaust.
Old Jan 31, 2004 | 01:17 AM
dr3d1zzl3's Avatar
Car Info: 08 sti
that does not sound good at all.. u taking it in soon i hope..
(for oil to be coming out the bov it sounds like you have a blown turbo seal or worse, but that would be causeing you to misfire on more then just 2 and 4..)
Old Jan 31, 2004 | 01:45 AM
taking it in Monday
Old Jan 31, 2004 | 08:05 PM
Br1t1shguy's Avatar
Car Info: 02' WRX
a bad. bad. bad turbo seal.
Dont drive it if you can avoid it, the turbos going to seize, you're going to foul the cylinders, and the rings are going to flood.
Old Feb 5, 2004 | 11:16 AM
WRXPRESS's Avatar
Car Info: 2004 Silver/Silver STi, '99 Ducati 900ss, Yamaha Blaster
damn...that sucks man...good luck.
Let us know what happens
Old Feb 5, 2004 | 05:56 PM
No problem I let you guys know what happens.
Old Feb 6, 2004 | 06:33 PM
invidia downpipe, injen intake, JIC coilovers, lineage grounding kit
Old Feb 6, 2004 | 07:03 PM
MJU1983's Avatar
Car Info: 06 Armada, 03 WRX, 05 STi(sold), 05 Vette (sold)
I have seen misfires happen when the intake air temp sensor reads that your car is too hot and begins to dump fuel.
If the oil problem goes away you have nothing to worry about. It could be the seals of your turbo. A small amount of oil is ok, a larger amount is not.
HTH
-Mike
www.axispowerracing.net
Old Mar 10, 2004 | 01:35 PM
I took my car to the dealership they told me it was because my timing belt jumped a 1 1/2 teeth. They are waiting for the parts to come in. After they work on my car I will inform everyone.
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
