Problems starting (on '04 STi after removing and re-installing turbo)
Old Feb 25, 2006 | 08:19 PM
04EsTi's Avatar
Car Info: 04 STi
Problems Starting...
Today I took out my VF39 turbo to go get the wastegate ported.. When I get there they tell me I have a cracked compressor housing, which I do. So I take the turbo back I put it back in and primed the oil pump.. Hook everything put the top mount on and everything ready for a start. Tried starting it and it didnt start. Kept the key in the on position and noticed a buzzing coming from the throttle body and took the top mount off to check it out. We looked in the throttle body and noticed that it wasnt closed all the way. It continued to buzz and tried reseting the ECU, no luck.. We are out of ideas on what to do. Wondering if anybody can help.
Its a 04 STi, with Turbo back exhaust.
Thanks,
Old Mar 3, 2006 | 01:02 PM
JOHNNY HOPE's Avatar
Car Info: TOYOTA
Whoops
The Problem Must Be Something You Caused Is Air Flow Meter Pluged In Does It Crank Over Check Engine Light On Any Codes?
i<3dirt
Oct 20, 2014 10:26 AM
grex767
May 27, 2006 10:37 AM
Dre2932
Aug 23, 2004 07:52 PM
hansolo
Nov 7, 2003 09:48 PM
GLturbo
Jan 29, 2003 10:48 PM
