P2016 - 2005 Subaru Baja Turbo
Old Feb 18, 2013 | 05:05 PM
lzmperu's Avatar
Car Info: 2005 Subaru Baja Turbo
Smile P2016 - 2005 Subaru Baja Turbo
Hello everyone, I need help. Long story short i have this P2016 code, Intake Manifold Runner Position Sensor/Switch Circuit Low. I have read a lot about deleting the TGV valves, but i haven't found anything of a tutorial of how to fix it. I have swapped the sensors. P2016 is referring to the one the passenger side, right next to the turbo, i swapped it with the one from the other side to see if the problem was the sensor, but i still have the same code. it means the sensor is not problem. It is either the wiring some thing else. i have read a lot of how install the sensor and the TGV motors.
Does anybody have any tutorial of how to fix this issue, or what pin in the ECU to check for continuity to see if the wire of defective.
I am not planing to doing anything crazy with my Baja for now. I have contacted COBB and they say that they dont have an Accessport meant for my car. I have also contacted a couple of motorsport shops around my area to see if the could tune my car with maybe open source and they said no, they need the Cobb Accessport for that.
I need to smog my car ASAP.
Thanks a lot, I am counting on you guys.
Old Feb 18, 2013 | 05:57 PM
lzmperu's Avatar
By the way my Baja is 100% stock
Old Feb 18, 2013 | 07:19 PM
Blazingbuda40's Avatar
Car Info: 2004 Forester XT
The motor is the same as the forester and the wrx isn't it? Do you know if the ecu is any different ? If not you could just use the forester/wrx one
Old Feb 19, 2013 | 10:03 AM
lzmperu's Avatar
I am looking for a repair guide like Alldata. Does anybody have that software available?
Old Feb 19, 2013 | 11:28 AM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
you looking to sell the Baja?
I know someone that is looking far and wide to purchase one.
Old Feb 20, 2013 | 05:29 AM
lzmperu's Avatar
it's not for sale
I am not selling it. I just bought it 3 weeks ago and I had to drive 4 hours to buy it. I wish good luck your friend finding one. I just want to fix it and keep it stock for at least a year.
Old Feb 21, 2013 | 07:46 PM
lzmperu's Avatar
Has anybody downloaded AllData from the torrents ?
Old Mar 14, 2013 | 09:50 PM
lzmperu's Avatar
So, i ended up buying the subscription from Alldata. it was pretty helpful. It shows you the connector from the ecu. I checked the resistance and it ended it being the sensor. I bough them from eBay. I replaced it and the car passed smog.
Old Jan 7, 2014 | 05:32 PM
Mwizard's Avatar
Car Info: 2002 WRX Stage 2 upgrade and Formula Ford
Still driving the Baja Turbo? How do you like it? Done any upgrades? Man or auto? I am considering looking for one.
Mark
jdawg707
Feb 1, 2010 01:58 PM
Nick Koan
Rally
Oct 24, 2004 04:18 PM
vitokd
Jul 8, 2003 09:36 AM
shaft73
Apr 27, 2003 02:22 PM
RallyKeith
Apr 22, 2003 07:17 PM
