Open or Catless downpipe?
Old Nov 3, 2009 | 09:10 PM
GripItUp's Avatar
Car Info: 2007 WRX Tr
I have a RS*R catless downpipe, and lately Ive been thinking about getting a catted one, since I really do not want to go through the trouble of changing it when smog time comes and Im really tired of cops looking at me when the smell of gas is going around.
My question is, will I get the same amount of power from a catted downpipe, and will I still be able to pass smog with a bellmouth catted DP?
Thanks.
Old Nov 3, 2009 | 09:27 PM
04caliwrx's Avatar
Thanks.
No that's why people run catless because of the power difference. Get a quiet catback and u should be fine. It's also not hard at all to put a stick down pipe back on.
Old Nov 3, 2009 | 09:28 PM
dogcatfud's Avatar
Car Info: 2015 FR-S
You will generally get more power from a catless downpipe compared to a high-flow catted downpipe. The difference should be negligible at stage 2 power levels. But since you are concerned about the raw fuel smell attracting police attention, you should go catted.
All downpipes are illegal, even catted ones. Though catted downpipes will usually pass the sniffer, they won't pass visual... unless you go to a shop where the smog techs are lax.
Old Nov 3, 2009 | 09:46 PM
GripItUp's Avatar
So when tuning my car, the power is not much different compared to the two types of DP's?
Thanks guys.
Old Nov 3, 2009 | 10:08 PM
dogcatfud's Avatar
Car Info: 2015 FR-S
If you want more "exact" HP numbers for catless vs catted, you should probably talk to a tuner.
Old Dec 8, 2009 | 02:29 AM
WRX409's Avatar
Car Info: 04 WRX
A catted downpipe should indeed pass the sniffer but,will
not pass the visual part though you can ask people what
shops in your area that will pass you on the visual part of
the smog test.
Old Dec 21, 2009 | 11:06 PM
06WRXtacy's Avatar
Car Info: '06 SGM WRX / 18G (300/291) RIP, '05 TB Evo VIII
Cat-less will give you more top end and quicker spool. My catted Titek stank much worse than stock so I gave in and went cat-less. Never looked back. It's not a hard decision considering you're breaking the law with either one you choose. Plus I was able to sell the hi-flow, buy the cat-less and still pocket a bunch of cash
Old Dec 22, 2009 | 02:55 AM
ERZperformance's Avatar
catted downpipe will not pass smog in CA.
Old Dec 25, 2009 | 10:41 AM
klenboy's Avatar
The response on a catless DP is significantly better than a catted DP. Even just on Stage 2 power it is highly noticeable.
flatline
Aug 3, 2008 11:38 AM
LunarHonour
Jun 25, 2008 10:21 PM
BoxerRumble
Mar 18, 2007 07:46 PM
SG5
Oct 7, 2006 11:19 PM
1FSTREX
May 15, 2006 11:16 PM
