Oil blowing out of dip stick problem?????
Old Dec 19, 2009 | 07:17 PM
REXX13's Avatar
Car Info: 03 SILVER REXX, 2.5ltr, vf34, sti cooler
For some reason my oil dip stick keeps getting blown out and then oil gets blown all over. I have no clogged emission lines. I took out and cleaned my PCV valve. It was'nt stuck or anything before I cleaned it.
Has anyone had this problem.
03 WRX. I have a 2.5 motor with 2.0 heads. Sti TMI and a vf 34 turbo, sti pinks and a reflash.
If anyone can please help with this it would be great.
Thanks, Troy
Old Dec 20, 2009 | 10:32 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
This can happen from excessive blow-by which usually means you have an internal engine problem. Pop off the oil filler cap while the car is running and rev it a bit. If you see white puffs of smoke coming out, you most likely have a cracked piston ring land. If you do see smoke, I would recommend doing a compression test to verify.
-- Ed
REXX13
Dec 20, 2009 03:42 PM
RupeDawgPSU
Dec 8, 2007 01:13 PM
Max Xevious
May 31, 2005 07:08 PM
BlkRx
Oct 1, 2003 04:31 PM
1wrx2goplz
Feb 5, 2003 09:50 PM
Top
