Not too shabby for a stock peashooter on the heartbreaker!
Old Aug 20, 2007 | 05:43 PM
  #61
earlyapex's Avatar
From: I wuv imprezeR with all muh heartz. CareBearZ fur
Car Info: 05' Evo MR w/E85 - 10' Ralliart Sportback w/E85
The FP big16g for subaru uses a 7cm turbine housing.
The stock 16g for the 05 evo 8 and Evo 9 uses a 10.5cm turbine housing.
The stock 16g for the 03-04 evo uses a 9.8cm turbine housing.
The big16g for the DSM's uses a 7cm turbine housing.
Not all "big16g's" are created equal.
The FPgreen for the subaru uses a 7cm turbine housing.
The FPgreen for the evo uses a 10.5cm turbine housing.
However, its the turbine housing design and wheel size and design that really matters.
Old Aug 20, 2007 | 05:44 PM
  #62
ucbsti's Avatar
Car Info: 2006 evo IX
lol brain fart...
Old Aug 20, 2007 | 09:09 PM
  #63
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
Medway is evo gawd, all must bow before him!
Old Aug 20, 2007 | 09:34 PM
  #64
03_Impreza_Al's Avatar
I needs me a vf39
Old Aug 21, 2007 | 12:16 AM
  #65
blinguskahn's Avatar
From: Leaving on a jet plane dont know if i'll be back..
Car Info: 05 STi White v2 8cm FP Red
That was really useful information there bro
Honestly, Bryan wouldnt even consider himself an "evo gawd". He simply works hard at what he does, takes him time and double checks everything.
Old Aug 21, 2007 | 04:20 PM
  #66
STiYLIN's Avatar
back on topic, I need to start selling "oranges" to savemoney for my Green ($1500 OUCH!)
That way I can make this on 91 and the 104 map will be wicked.
Old Aug 21, 2007 | 04:35 PM
  #67
pj21086's Avatar
you were running 23 psi on 91 oct?? thats a lot of boost for the vf39. i made about 5hp/tq less with only 16psi.
Old Aug 21, 2007 | 05:11 PM
  #68
STiYLIN's Avatar
I run 1.5 bar on 91 (sometimes w a gallon of 104 for knock protection) so yes, but the gauge is .1 high so maybe 1.4bar
Running 1.8 :O on 104
Old Aug 23, 2007 | 11:00 AM
  #69
STiYLIN's Avatar
Ok with a help froma long time drag racer he says I should be shifting @ 5600rmps do to my dyno graph.
So my dyno is here
And here is the gear ratios for my STi and how I should be shifting and what it will drop to rpm wise.
Any other drag racers want to put their input in that have experience with this stuff?
Old Aug 23, 2007 | 05:06 PM
  #70
5600 is way too low. You are going to have to shift close to redline.
Old Aug 23, 2007 | 05:09 PM
  #71
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
if you shift that low, you will be way out of the power band for the next gear.
although your HP levels off, I would still take it to 7k so the next gear will be higher in the RPM and your power will not fall off as much.
Old Aug 23, 2007 | 10:29 PM
  #72
pj21086's Avatar
earl (EJ257) shifts at 6k and consistently runs 12.2's on his stock turbo
Old Aug 24, 2007 | 07:00 AM
  #73
STiYLIN's Avatar
Doesn't the graph show that I will fall into the best part of my powerban if I shift @ 56-5800. Makes it drop to the mid 4k's where I am PULLIN.
abakja1
Oct 9, 2013 03:16 PM
Electra
Jul 27, 2011 10:58 PM
gruppe-s
Feb 16, 2006 06:54 PM
gruppe-s
Exterior / Interior Lighting
Feb 16, 2006 06:44 PM
SubySal
Jul 2, 2004 04:13 PM
