need some help here!!!
Old Oct 2, 2009 | 08:54 PM
venom225's Avatar
Car Info: WRX STI 07
ok so i brought my sti to a shop to get rear diff bushings changed as i dont have the tools to get the studs out (attempted and failed) but thats beside the point. the mechanic obviously was ignorant enough to think that the rubber that sits inside the rear subframe outrigger (not to be confused with aftermarket outrigger bushings) was the rear diff bushings...he shredded the rubber that resides in the outrigger in an attempt to remove it before looking at the instructions i gave him to see that HE WAS DESTROYING MY CAR....here is a picture
does anyone know if i can get new rubber for the outrigger or do i have to get something else...wow im pissed
after i blew a gasket he than changed the rear diff bushings free of charge and when i figure out how to fix what he broke then they will fix that to free of charge but im not sure how to fix it hmmm
Old Oct 2, 2009 | 10:28 PM
venom225's Avatar
anyone know were to get a rear diff subframe cradle? because i think thats what im going to need...a brand new one!
Old Oct 2, 2009 | 10:32 PM
Alliedforces86's Avatar
Car Info: FR-S + WRB Bugeye.
that sucks man sorry...
Old Oct 2, 2009 | 11:38 PM
06stibeast's Avatar
Car Info: 1993.5 toyota supra, 05 AW Sti
no clue man that sucks... call paul at dbtuned 791 4900...
Old Oct 4, 2009 | 03:47 PM
blkwagon's Avatar
Car Info: 2002 sedan sti swap high on meth
i ave on...i am in fresno tho
Old Oct 4, 2009 | 08:24 PM
venom225's Avatar
you have one for an sti?
Old Oct 5, 2009 | 09:06 AM
compton's Avatar
Car Info: bugeye ej257 / 6MT / cusco lsd
Yo
I am in the process of replacing mine right now. It is very difficult to remove them. There is a rubber bushing with a thin steel sleeve surrounding it. You can attempt to press this out. I had no luck so I am going to sawzall/ cut the steel collar and chisel it out then clean the surface and press my new Noltec bushings in.
Here they are
http://www.oakos.com/Merchant2/merch..._Code=NOL91379
Old Oct 5, 2009 | 02:50 PM
venom225's Avatar
awesome ill go this route since he has already mangled my outrigger bushings anyway...plus it will be a pita to do and i wont be doing it the shop will!!!! HAHA awesome!
Old Oct 6, 2009 | 10:57 AM
compton's Avatar
I had to cut mine on both sides of the bushing sleeve. Once they were cut I drove a screw driver between the sleeve and the housing. I did not have a chisel otherwise I would have used it. Once there was I nice gap the bushing popped out. They were in there for about 8 years so they were tough.
Kozmo
Sep 9, 2003 11:40 AM
Irok_1_wrx
Apr 29, 2003 01:13 AM
sub-sonic
Apr 24, 2003 09:37 AM
NeedWRXSTi
Mar 3, 2003 08:02 PM
