Mods for STi
Old Jul 8, 2004 | 10:15 PM
  #31
Krinkov's Avatar
Originally Posted by vmar900
as for performance, I would suggest a nice turbo back exhaust system. I have been working with Vishnu performance and all the numbers they claim have been right on the money. I don't beat on my car, and at the track, I am very conservative. My car is completely stock with the Vishnu turbo back, and pulled consistent 13.2 with a 1.8 60 foot times at Infineon raceway. I will hopefully be a test vehicle for Vishnu performance, and hopefully will come out with some really great bolt on mods. You pay for what you get, but if you get the Vishnu stuff, there will be no disappointment.
c'mon shiv, you know your suppose to post in the vendors forum
Old Jul 21, 2004 | 11:28 AM
  #33
SlvSurfer's Avatar
Originally Posted by Imprezer
Turboback exhaust is a must. Rear sway bar and better brake pads.
Don't forget stainless steel brakelines.
Old Jul 23, 2004 | 05:31 PM
  #34
PyroManiac's Avatar
From: Are you too one of the few still living the past? Well I can change that! With a simple wicket. Yes, my friend, a wicket. PM for details.
Car Info: No car right now....sob.
This isn't really a mod, but the "snorkusectomy" is a good one. (Remove the intake silencer.) Takes 20 minutes with a friend, and is free. Provides better sounding turbo, and allows the turbo to spool up a couple hundred RPM sooner.
Old Aug 10, 2004 | 11:01 PM
  #36
Krinkov's Avatar
Originally Posted by J-REX
235/35/17 tires (needed more meat)
where the hell did you find these???
Old Aug 11, 2004 | 12:38 AM
  #37
Group B's Avatar
Dahveed aka Robin Hood
for $2,200 you can get the Vishnu Stage 1 upgrade, which is a TBE and Engine management (currently with XEDE, but re-flash is coming soon), and this is 260+hp to the wheels.
Hotchkiss competition sway bar set for Subaru STi. Chromemoly Hollow tube 1” front and rear, precision endlinks and mountings, rear 3-pos. adjustable. Cost new $586.
The Noltec or Whiteline steering rack bushings make a great difference, as will a set of JDM V8 STi Pink springs, installed on your stock struts.
Also, look into the Subaru factory short shifter kit, unless your car already comes with it. It costs $340(+/-) plus install.
Hawk HPS or HP+ brake pads, Performance Friction, or Ferodo's are all great pads, but install them once your pads wear out, they cost $300+ for the fronts.
Install some SS brakelines when you install the brake pads, you'll be very happy!
David
Old Aug 11, 2004 | 06:23 AM
  #38
Egan's Avatar
David
I got Ferodo DS2500's F&R for my STi for around $250 total. They performed quite well at the track.
Old Aug 23, 2004 | 11:02 PM
  #39
mnavarro's Avatar
Ok biggest bang for the buck is probably steering rack bushings at 29$
Here's what I'm doing with the engine:
Invidia Downpipe $250
Used SR40 Turbo $800
Perrin Mod Inj. $220
Fuel Pump $90
K&N Short Ram In $235
UTEC $1029
Tuning $250
Suspension:
Espelir GT springs $259
Perrin Rear Sway $200
Perrin End Links $100
Performance Alignment $100
This is about 3.5K Total
Future Mods:
Brake Pads/SS Brake lines
Steering Rack Bushing
PS Did not include radio but this is essential
Old Aug 24, 2004 | 01:50 PM
  #40
gt42sti's Avatar
Thumbs up
Ok,
What about some tuning? Best performance bang for the buck is the Accessport...IMHO. You have the choice of several maps to tune for the best gas and upgrading mods at a later date. ~650
Then go for the downpipe and bump the Accessport up to stage 2 and your set to go on a budget. ~300 Do you really need the cat-back exhaust for added power? Not really...other than looks or sound. Unless you really go nuts with mods the stock cat back works great.
I had some severe detonation when we moved to Oregon so I opted for the Accessport instead of taking my car in to the dealer. Results are fantastic and the dealer didnt have to mess with the car...I just loaded up the 91 octane maps and presto!
Good luck...my ball is in the tuning court.
Dave
Old Aug 30, 2004 | 04:38 PM
  #43
Group B's Avatar
thanks!
Old Sep 25, 2004 | 03:57 AM
  #45
Is it really pulling to one side, or is the steering wheel just uneven? It's not unusual for the wheel to be a little off after doing steering rack bushings, but it shouldn't affect front toe.
