missing oil
Old Feb 25, 2005 | 05:27 PM
1sti36t's Avatar
missing oil
have an 04 STI with about 15k. In the last 3000 miles I have had to add 3 quarts!? I have no leaks and I do not notice any white, black, or blue smoke. I did notice a little oil dusted on my intake hoses but none sitting in my fmic. If any one has any info, please help. -Confused?
Old Feb 25, 2005 | 08:26 PM
tim's Avatar
tim
try checking the oil hoses that go to the turbo. one of my friends had a problem like that with a car that he had a while black and it was kinda hard to figure out because no oil was actually getting on the turbo, so it was not burning. I could be totaly wrong, but its worth a try.
Old Feb 25, 2005 | 09:57 PM
stott's Avatar
Car Info: 2004 STi Yellow/Black
obviously you are losing it somewhere. I suggest a compression test / leak down. When I had a similar problem I was at 100 100 140 140. Haven't pulled the heads yet but I'm guessing busted ring lands. I had similar symptoms to yours. good luck.
Old Feb 26, 2005 | 08:33 PM
1sti36t's Avatar
No power loss
No power loss, coolant is clean, oil is clean, and i use redline synthetic oil. I appreciate the help.
Old Mar 7, 2005 | 05:26 AM
ubar's Avatar
Car Info: 04 STi
I'm interested as well. My sti has less than 15k mi on it, always Mobil 1 at 3k intervals. One day I was heading home and driving fairly hard and noticed it was starting to make some light tapping noises from the engine... a full quart low.
Old Mar 15, 2005 | 02:32 PM
1sti36t's Avatar
within limits?
I went to my local Subaru dealer for a warranty claim, they told me that as long as I am not going through more than 1 quart of oil every thousand miles I am still within Subaru's set limits of oil consumption!? Any thoughts on this?
Old Mar 15, 2005 | 02:34 PM
stott's Avatar
Depends how much you are going thru. I just got done dropping a new shortblock in My STi. Ringlands were shot in 2 & 4.
http://www.stifiles.com
Old Mar 15, 2005 | 02:41 PM
1sti36t's Avatar
too much
I go through roughly 1quart/thousand, sometimes a little more.
Old Mar 15, 2005 | 02:56 PM
stott's Avatar
Well it is a turbo motor and they do tend to have more blowby. I was going thru about 1qt / 1000 miles before it got worse and I did a compression test.
Compression test is pretty cheap insurance, you can even do one yourself if you want.
Even when I was burning a LOT of oil there wasn't much smoke to give it away.
Old Mar 16, 2005 | 01:05 AM
Get them to do a compression check. If bad cylinder walls are the culprit (more likely than broken rings if you're not down on power) then you'll be getting a rebuild regardless of how much oil it's actually losing.
huck
Aug 23, 2017 02:18 PM
dorifto88
Aug 11, 2004 06:24 PM
catdogr
Jul 5, 2003 07:48 PM
Mach5WRX
Jun 27, 2003 02:52 AM
jdzumwalt
Jun 4, 2003 08:53 PM
