max psi for wrx
Old Jul 22, 2006 | 12:32 AM
wimprezax06's Avatar
Car Info: WRX --> RX-8--〉E93
max psi for wrx
hi guys mbc and i want to turn up the boost level, my is a 06 wrx, i turn it up
around 15 psi today and i just wondering how much can my wrx hold the max
thx
Old Jul 22, 2006 | 01:13 AM
hokusai's Avatar
Car Info: a Ford
I wouldnt use a mbc but "safely" i would leave it 14. Remember, boost spikes may occur. Make sure you have an EGT and boost gauge too just to be safe.
Old Jul 22, 2006 | 01:55 AM
Krinkov's Avatar
thx
1. Post this in the right forum.
2. Do NOT turn up your boost without tuning, EVER! This is a real fast way to destroy your motor, especially in this heat!
Old Jul 22, 2006 | 02:59 AM
hokusai's Avatar
Car Info: a Ford
Agreed! Listen to da man
Old Jul 22, 2006 | 05:55 PM
yes yes thx
Old Jul 23, 2006 | 02:55 AM
chineseguy's Avatar
Car Info: White 350z
good luck
Old Jul 23, 2006 | 02:56 AM
evo8dustu's Avatar
Car Info: 05 EVO MR
you can safely raise stock boost levels as long as you have the basic mods. intake exhaust. raising your boost a couple of psi higher wont hurt ur engine. you dont need a tune just to raise ur boost a couple of psis higher. just make sure you dont go too crazy, boost can be addictive ; )
Old Jul 23, 2006 | 06:49 PM
WRX409's Avatar
Car Info: 04 WRX
Talking
Correct sir. Leave it at 14.
Old Jul 23, 2006 | 08:04 PM
Cody8675309's Avatar
With tuning you can raise it a lot. Without tuning (and I recommend an EGT gauge) it's motorcide. The Hallman Pro RX MBC is an amazing upgrade.
Old Jul 23, 2006 | 11:56 PM
WRX409's Avatar
Car Info: 04 WRX
So,MBC's can be a good mod? From what I hear people say to stay
far away from MBC.How can they be safe? Any links?
Old Jul 24, 2006 | 09:42 AM
On a stock tune, they will cause problems including high EGT's from Partial throttle, full boost (PT/FB). Most aftermarket tunes compensate for this by transitioning from Closed Loop to Open Loop earlier. Still, datalogging after the MBC install and having an EGT gauge is the only way to go IMHO
The advanatage is much better boost response (I hated my slow response when I moved to 4500 foot elevation). On a 3rd gear pull from 2k-redline, I doubt the MBC changes anything, but when driving normally, especially in 1st and 2nd gears, it makes a big difference.
http://www.seccs.org/forums/showthre...ht=mbc+protune
Old Jul 25, 2006 | 12:00 AM
WRX409's Avatar
Car Info: 04 WRX
Lightbulb
Thanks alot Cody.That is very intrusting.
I don't plan on putting MBC on my car but, that is some
good info to know.
Old Jul 25, 2006 | 12:01 AM
No problem.
Daddyz808
Feb 6, 2013 06:32 PM
billthestill
Mar 18, 2004 01:03 AM
04.Sti
55
May 21, 2003 02:35 PM
rednek wrx
26
Mar 14, 2003 01:38 PM
blackwagonrx
Jan 31, 2003 02:03 PM
