Stock Turbo-Max PSI???
Old Mar 16, 2004 | 03:31 PM
WRX_2NR's Avatar
Car Info: 04 WRX
the turbo specs are about the same as a VF30 or 34
If your going to put the turbo on the WRX the ECU will fuel cut at 18psi & throw a CEL
Old Mar 16, 2004 | 04:46 PM
RussB's Avatar
Car Info: $200,000 sports car
you have an STi? i wouldn't screw around with boost controllers on a $30k car. wait a bit and the ECUTEK software will be able to tune that car and it's much safer and effective than a boost controller.
Old Mar 16, 2004 | 05:42 PM
WRX_2NR's Avatar
Car Info: 04 WRX
well if you can't control the fuel for the added boost.
DON'T crank up the boost. You'll blow the engine
You need proper fuel management to do that
Old Mar 16, 2004 | 07:15 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Go for custom dyno tuning. I have a pic of a guy who's turbo blew out of his hood because of nonsense like that all black and burned. Get some bolt ons then go for the custom dyno tune. It'll do good.
WRX Rush
Old Mar 17, 2004 | 09:28 AM
RussB's Avatar
WRX Rush
TTIWWOP
Old Mar 18, 2004 | 01:03 AM
snicklous's Avatar
Car Info: '03 Wrx w/vf-34, sti pinks,tbe, 2.5l cobb block
i believe that the sti has a vf30 turbo in it. but i agree with WRX_2NR. if you don't have the fuel the bump up the boost don't do it.
Daddyz808
Feb 6, 2013 06:32 PM
CaliSuby
Apr 5, 2011 05:46 PM
wimprezax06
Jul 25, 2006 12:01 AM
rednek wrx
26
Mar 14, 2003 01:38 PM
blackwagonrx
Jan 31, 2003 02:03 PM
